Some are fitted with manual type controls, while the rest are fitted with digital climate controls. For both, the rear system needs to be switched on from the front, for the slider type controls the rear heater system has an on/off master switch, situated to the right of the drivers steeing wheel on the main dashboard switch panel. For the Digital climate control, there is a switch on the control panel labelled "Rear" this can be used to control the fan speed & mode in the rear (but not the temperature bizarrely) by holding down the rear button for a few seconds.
The front fan is prone to water ingress, which gets into the motor bearing, either siezing it up completely or causing sufficient friction to increase the current drawn, thus causing damage to the fan resistor packs. It's worth trying to repair these before resorting to the cost of replacing them, many have done so succesfully with the help of the factsheets & forum.
There is a drainage hole in the bottom of the fan casing that can get blocked. This hole is larger on the new replacement part, so it's worth enlarging the hole if you're stripping it down.
If the front fan is blowing ok, but the flaps don't seem to be directing the air to the desired outlets, check the linkages on the inboard side of the drivers footwell, these are prone to breaking or coming adrift.
All this & more is detailed in the links below.
Air conditioning Factsheet click here
Climate Control Unit Illumination Factsheet click here
Fan Speed Resistor Factsheet click here
Front Heater Factsheet click here
Heater Repair Factsheet click here
Bongo Clinic Archives click here
Schematics courtesy of Lushprojects (Info used from Diesel engine manufactured between Nov 97 to Aug 99 there may be some slight differences with your model) click here:
Belts, pulleys & adjusters
Air ducts
Heater components
Heater control 2
Heater control 1
Heater components
Rear heater
Rear heater components
Air conditioning 2
Air conditioning 1
Air conditioning
Air con compressor
Evaporator
Rear air conditioning
Rear cooling channels & vents
Forum discussions past & present, click here:
Air con
Front heater
Heater Fan
Heater controls
Rear heater
Climate control
Fan resistor pack
If you can't find what you're looking for in all that lot, try using the search function, top right. It can be a bit temperamental, but if you use a multiple word search and use the word "and" between each word, eg front and fan, you should find what you need.
Alternatively, get on the forum & join in
