V6 Power Problems...help!
BongoNog
Post by BongoNog » Sat Feb 14, 2009 12:39 pm
Being the proud owner of a V6, I took it with me when I emigrated to Norway last year. I've yet to see another Bongo in West Norway, but neither have the garages :shock: ! Hopefully someone can help...Everything was fine when we drove back to Scotland in October, however after the service at a local garage we had a very rough sounding engine and a loss of power (and a very long drive back). I suspected that the spark plugs the garage had changed were the wrong type so I changed those out and noticed that the ignition leads had been 'leaking' with burning and char marks around the spark connection. The spark plugs also showed heavy carbon build up. The power problems have since got worse, the van refuses to change down and struggles up even slight gradients, so much so its undriveable :cry: . I replaced the igniton cables and spark plugs (again) today but to no result. I'm thinking the next step is to change out the distributor cap & rotor arm, but this is getting expensive, so any helpful suggestions much appreciated! My Bongo is an 01 model SG-5W Friendee. Many thanks, BongoNog
Re: V6 Power Problems...help!
Post by bigdaddycain » Sat Feb 14, 2009 12:47 pm
Hi, And welcome.... Are you back in Norway with your bongo at the moment?
dandywarhol
Post by dandywarhol » Sat Feb 14, 2009 1:13 pm
The distributor cap seems to be vulnerable on the V6 and moisture can get into it causing the problems you describe
manners
Post by manners » Sat Feb 14, 2009 1:19 pm
Carbon deposits on the plugs can be caused by many different conditions. Carbon deposits build up when the plug fails to fire correctly and burn them off. Air/fuel mixture too rich, choke stuck on, electrical problem, extended periods of low speed driving, plug heat range too cold. All should be investigated.
BongoNog
Post by BongoNog » Sat Feb 14, 2009 6:18 pm
Folks thanks for the welcome and tips. I'm back in Norway and it is certainly cold! I'll take the distributor cap off tomorrow and see if I can see anything (and give it a clean while I'm at it.) I'll work through manner's checklist, but outside mechanics are a bit tricky at the mo. as its -9 outside :-&
Incidentally I got the new ignition cables from japautosolutions - pricey but genuine parts and they shipped to Norway. With regard to plugs I found the following recommendations on various makers websites for Japan..
NGK BKR5E-11 (what I'm using) or IK16 Iridium Power
Denso k16PR-U11
Plug gaps seem to be 1.1 mm, although I can't find anything to confirm this.
Dolly1
Post by Dolly1 » Sat Feb 14, 2009 8:45 pm
Are the plug leads on the correct plugs,one could be wrong. ??
SARAH & LIONEL - I Used to be Citroen 2CV "DOLLY" mad but BONGO-MAD lady with not so mad husband now!
Post by Ian » Sat Feb 14, 2009 8:54 pm
Distributor cap is about £50 from Mazda.
Post by francophile1947 » Sat Feb 14, 2009 9:01 pm
BongoNog wrote:Plug gaps seem to be 1.1 mm, although I can't find anything to confirm this.
That seems to be a very large gap :? 1.1mm is about 43 thousandths of an inch - I seem to remember plug gaps usually being around 25thou (0.63mm) - maybe times have changed cos' I haven't had a petrol car for years 8)
cheffy34
Post by cheffy34 » Sun Feb 15, 2009 3:53 am
Is it actually missfiring :?: I had my leads made for £40 hyundi lantra ends for those that are interested i have a contact number he kept measurements and can nock em up :wink: the cap on mine has been prone to water ingress when driving in extreme heavy rain and standing water, water gets in and lies at bottom of cap knocking out middle cylinder on nearside bank and both end cylinders on offside back :!: deep standing puddles hit at any speed sends water up through the scav fan on a collision course with the dizzy :evil: Thats if it water, the gap is usually the last digits on the plug aren't they :?: i remember summit about 11 being 1.1 on the plugs, get your cap off and have a butchers mine ain't bad but original i suspect :roll: just cleaned it up, as manners says check all aspects, use this link to see what your plugs are telling you
http://www.theultralightplace.com/sparkplugs.htm
goodluck with it
Dar
BongoNog
Post by BongoNog » Sun Feb 15, 2009 10:51 am
Well, I took the cap off (after working out how to bend my arm enough to undo the blind screw on the bottom :? ) and it was dry inside, however the 2 & 5 contacts have completely eroded away. I also found that the cable configuration as inherited from the garage did not match up to the cap numbers :-s , possibly the cause of the wrecked contacts? Give that the fuel mixture is also too rich based on the plugs, I'm not surprised at the performance :!:
Can anyone point me in the direction of where to adjust the fuel-air mix? and which order the cables should be on the engine block? Looks like I'll be ordering a new cap & rotor arm in the meantime.
1.1 mm is the gap the plugs are set too from the manufacturer, I guess thats why the part nos end in 1.1 :oops:
Thanks again for everyone's help.
manners
Post by manners » Sun Feb 15, 2009 12:21 pm
The MAF, 02 or crank position sensor can all affect the mixture as if they are faulty they send wrong info to the ECU. I think the firing order is from the front drivers side 1,3,5 and 2,4,6 on the passenger side but I'm not 100% sure on that.
cheffy34
Post by cheffy34 » Sun Feb 15, 2009 2:56 pm
Wouldn't start if it were crank sensor i thought :?: or am i wrong manners :!: i took my maf off and cleaned it with carb cleaner it helped smooth up the running
Dar
BongoNog
Post by BongoNog » Sun Feb 15, 2009 3:20 pm
While I'm waiting for the new bits, I'll have a go at cleaning up the rest of the engine & electrics and check all the filters. A bit of TLC might make all the difference. I'll let you know how I get on.
dandywarhol
Post by dandywarhol » Sun Feb 15, 2009 9:54 pm
BongoNog wrote:Well, I took the cap off (after working out how to bend my arm enough to undo the blind screw on the bottom :? ) and it was dry inside, however the 2 & 5 contacts have completely eroded away. I also found that the cable configuration as inherited from the garage did not match up to the cap numbers :-s , possibly the cause of the wrecked contacts? Give that the fuel mixture is also too rich based on the plugs, I'm not surprised at the performance :!:
Before you start messing about with the air/fuel mixture you'd be best to sort out the distributer cap - if it isn't sparking properly it'll make the plugs wet and seem rich................................
25 thou was the norm for contact breaker setups 30 years ago franco - plug voltages are around 3 times that nowadays - 25/30,000 volts not unusual, so a large gap can be used to help burn all the gas
apole
Post by apole » Mon Feb 16, 2009 10:38 am
Hi there,
Stick with fixing the HT side of things first.
I've had a blip on mine recently and I'm looking into the Disty cap, rotor arm, king lead and maybe the coil. All of that from Mazda is £129 inc delivery and VAT, disty cap is £43, rotor arm £9 but these things can be inspected first. I don't think an individual HT lead failure will lead to such power loss. The disty cap does have numbers on it by each connection. If you go for a new disty cap don't forget the O ring to prevent water ingress.
Spark plug gaps are 0.9mm from memory on the denso plugs.
You can do a rough test on the lambda sensor, google it and you will find plenty of sites but that is not the primary cause of your problems.
Andy
