Driver & Passenger Doors hard to shut
Triple/R
Post by Triple/R » Wed Feb 11, 2009 10:00 am
Dont know if this is in the right section--but it's technical to me-i'm chuffed to bits with me Bongo but the drivers side door & passenger door seem hard to shut both me & the missus have to really give it a slam usually twice to shut them--they seem to be lined up ok--everything else about the Bong seems car like -as in general driving but the doors let it down for me--anyone got any ideas?????
Ray.
Regards Ray & Christine
Dolly1
Re: Drver & Passenger Doors hard to shut
Post by Dolly1 » Wed Feb 11, 2009 11:14 am
Hi and welcome.
Perhaps the door mechanism has dried out.
Try WD40 to free it,followed by a light oil.
SARAH & LIONEL - I Used to be Citroen 2CV "DOLLY" mad but BONGO-MAD lady with not so mad husband now!
Post by teenmal » Wed Feb 11, 2009 12:06 pm
Hi as said above,oil the hinges if the doors are stiff to open and close.
If the doors are hard to slam shut you may need to adjust the striker plate on the pillar.
Cheers Malc..
Ron Miel
Post by Ron Miel » Wed Feb 11, 2009 12:33 pm
You're not 30 stone Americans are you? :wink:
Triple/R
Post by Triple/R » Wed Feb 11, 2009 1:32 pm
Thanks for replies so far--the doors are'nt stiff on the hinges it's just when you shut them to--will be out for the rest of the day so will have a go tomorrow.
As for 30 stone Americans :lol: no were lightweight Brits :lol:
Ray.
Post by mikeonb4c » Wed Feb 11, 2009 2:17 pm
I think (on my 95 model at least) Bongo doors are not as light as (modern) car doors and do require a proper firm closing action. But nothing I wouldn't expect on 'van' doors - they are big things compared to most cars and probably - being the kind of vehicle it is - the designers reckoned owners wouldn't want the kind of door that shut too easily while you are taking stuff in and out of the car, or just want doors open for ventilation etc. (least ways, those characteristics are an advantage in a campervan as far as I'm concerned!).
Oh and welcome - great cards aren't they? 8)
technophobe
Post by technophobe » Wed Feb 11, 2009 7:54 pm
The doors could have dropped slightly through previous misuse. It may be necessary to inset a thingy on one hinge on each side.
Richard & Jo
brorabongo
Post by brorabongo » Wed Feb 11, 2009 8:07 pm
It's must be all in the technique? as Whenever I have a passenger other than the wife, the door is never shut properly first time. (My mother normally takes two or three attempts. :lol: )
ボンゴの激怒 pictures
stringman
Post by stringman » Wed Feb 11, 2009 9:16 pm
I'd also make sure the door seals are fitted properly.
Also see if it makes any difference if you have a window slightly open when you close the door
Tin top Bongo camper, Peugeot Partner Combi, Kawasaki ZRX1100, Yamaha SR250SE
mikexgough
Post by mikexgough » Wed Feb 11, 2009 9:25 pm
mine were better after some TLC with the spray grease.......when I got my Bongo it hadn't been far for 6 months so things were a little "dry", the vehicle was serviced but they didn't do the extra bits like lub hinges/strikers etc [-X [-X
trevd01
Post by trevd01 » Wed Feb 11, 2009 10:16 pm
I can't say I have ever given a thought to it. On our Bongo the front doors open and close like any other vehicle. I am not aware of there being any 'knack' to it.
So if you have problems, it sounds like the door needs adjusting or lubricating as suggested above.
Triple/R
Post by Triple/R » Thu Feb 12, 2009 9:43 am
stringman wrote:I'd also make sure the door seals are fitted properly.
What a lot of info from all of you--yes it does make a difference with window slightly open but when your locking up, the windows obviously have to be closed & the doors seem harder to close from outside.
Can't have a proper look yet had plaster taken off my leg yesterday (after a break) so not very mobile yet.
But when i'm back in action i'm sure i'll sort it out with all the info given.
Regards Ray.
