Coolant leak behind the starter motor
dobby
Post by dobby » Fri Jan 30, 2009 7:26 pm
My bongo has sprung a leak, there's a pretty steady trickle of coolant running down the block from behind the starter motor. Does anyone have any idea where it may be leaking from? Fortunately the coolant alarm saved the day (THANKS Haydn!)
Any advice would be much appreciated.
Re: Coolant leak behind the starter motor
Post by haydn callow » Fri Jan 30, 2009 7:31 pm
There is a pipe that leaves the engine and goes to the rear heater...often goes....just replace it...easy job....
dobby
Post by dobby » Fri Jan 30, 2009 7:34 pm
Cheers, would it be hard to see that pipe with the starter etc in place.
Post by haydn callow » Fri Jan 30, 2009 7:40 pm
No..it runs across the top of the starter..... just be carefou you don't brake the metak pipe that it goes onto at the engine end...these in fact can corrode away so make sure it is solid...the stub pipe can be replaced if it's at all dodgey...probably the hose though.
lizard
Post by lizard » Fri Jan 30, 2009 8:01 pm
haydn callow wrote:No..it runs across the top of the starter..... just be carefou you don't brake the metak pipe that it goes onto at the engine end...these in fact can corrode away so make sure it is solid...the stub pipe can be replaced if it's at all dodgey...probably the hose though.
Hi there, when my hose went, it was the metal pipe as well. Allans plymouth made one up for me, a nice stainless one, great fellows.
F Zappa
dobby
Post by dobby » Fri Jan 30, 2009 8:23 pm
Thanks chaps, trouble is I've just had a look at it and seen the pipe described but it's as dry as a bone. Whilst below the starter its wet :(
Peg leg Pete
Post by Peg leg Pete » Fri Jan 30, 2009 8:30 pm
If it is a pinprick leak it will not show up as easily :roll:
Image Pete
dobby
Post by dobby » Fri Jan 30, 2009 8:32 pm
Hiya Pete
I thought that but there was a load of water running out from under the engine and nothing anywhere near that pipe.
Worried now that the coolant loss is too great to risk a top up and run of the engine without a full bleed on a leaking system.
Peg leg Pete
Post by Peg leg Pete » Fri Jan 30, 2009 8:34 pm
I would not run your bongo again till you have sorted the leak, checked all your hoses and bled the system.
Image Pete
dobby
Post by dobby » Fri Jan 30, 2009 8:47 pm
I agree, It's a weird spot for a leak - it runs down behind the starter motor. The core plugs look ok and there's no sign of any water above the start motor (on the block, pipe stub etc). Next trick is to have a go tomorrow and then if that fails track down a bongo friendly garage near me.
dobby
Post by dobby » Sat Jan 31, 2009 12:21 pm
Had another look at it this morning, all the core plugs are dry and the hose above the starter motor is ok. However, there's water and coolant inside gearbox bell housing and when I pulled the bung out the bottom of the housing coolant flooded out.
What is it that could leak and fill the bell housing?
Any ideas?
Post by teenmal » Sat Jan 31, 2009 1:17 pm
hi dobby.
have you checked h the core plug at the rear of the cylinder head.
Cheers Malc..
dobby
Post by dobby » Sat Jan 31, 2009 1:49 pm
Thanks Malc
It was Dry
Odd thing is the water is inside the gearbox housing as when you take the bung out at the bottom there's coolant in there. I wouldn't think there's a hidden core plug behind a bell housing on the block. Also, I cannot see anyway that water can get in from the top. I spoke to Michael at wheelquick who was most helpful and suggested I check the metal pipes above the 'box but they are much further back.
I think I'll book it into the garage in Market Drayton that's been recommended.
Post by missfixit70 » Sat Jan 31, 2009 1:58 pm
Have a good poke around the drawing at lush projects - http://www.lushprojects.com/bongopartsm ... Atr.html#6 may help :?
dobby
Post by dobby » Sat Jan 31, 2009 2:32 pm
Thanks Kirsty
I've had a good nose around on there already and all the schematics face forward - there's no rear elevation of the back of the block but I'll keep on looking
Very worried now
