ROOF MOUNTED DVD
- Tribal Elder
ROOF MOUNTED DVD
HI THINKING OF FITTING A ROOF MOUNTED DVD SYSTEM ,WHO EASY WILL THIS BETO FIT OR NOT THE IF THATS THE CASE.
Re: ROOF MOUNTED DVD
hi stevie I fitted my DVD/Tv by bolting on to the sliding roof glass cover.Removing the retaining rail screws was tricky due to lack of space and locktite.Unfortuneately there was some sag which prevented the latch from working efficiently.I stuck on some velcro fasteners to overcome this,and on the front of the slider to stop the screen sliding back when the roof is raised.Maybe some stiffening material on the topside of the slider would have been useful.Also be sure the depth of the unit fits in the gap between the slider and upper bed.
The beauty of this system is when the system is not in use its hidden from view.
hope this helps.
hope this helps.
