Hold Light
Huw
Hold Light
Post by Huw » Fri Jan 23, 2009 6:00 pm
Hi the hold light came on yesterday and stayed on, NOT flashing just on. Until we stopped the car and restarted then it went off. What is the Hold light for? and why did this happen? any ideas folks? thanks
clark282
Re: Hold Light
Post by clark282 » Fri Jan 23, 2009 6:10 pm
I had a similar thing. Took me a a couple of mins to work out.
There is a button on the gear stick. when pressed the hold light comes on. This Holds the gear box in the gear you are in. It is used for when you are going up a steep hill and dont want the auto gear box to change up.
Re: Hold Light
Post by francophile1947 » Fri Jan 23, 2009 6:12 pm
You pushed the Hold button on the gear lever - it cancels when the engine is turned off 8) :lol:
Re: Hold Light
Post by bigdaddycain » Fri Jan 23, 2009 6:16 pm
clark282 wrote:I had a similar thing. Took me a a couple of mins to work out.
Or in my case..an engine brake. :wink:
Re: Hold Light
Post by mikeonb4c » Fri Jan 23, 2009 6:30 pm
Agreed - I use mine as part of almost every stopping / slowing down manouevre. Well, I'm not rushing to have to replace the disc pads :lol:
clark282
Re: Hold Light
Post by clark282 » Fri Jan 23, 2009 6:33 pm
engine brake?
Re: Hold Light
Post by missfixit70 » Fri Jan 23, 2009 6:50 pm
clark282 wrote:engine brake?
Like changing down in a manual car & using the drag of the engine to slow the car, as recommended down steep hills where it says "low gear" :wink:
Re: Hold Light
Post by bigdaddycain » Fri Jan 23, 2009 6:52 pm
It can restore that feeling of control when used to driving a manual... It's especially useful if you are on a long, slight descent, with lots of bends. :wink:
cheffy34
Re: Hold Light
Post by cheffy34 » Sat Jan 24, 2009 3:45 am
MMMMMMMMMMMM =P~ In my v6 it for overtaking :D :wink:
