V6 MOT Failure Emissions
flippa
Post by flippa » Fri Jan 09, 2009 8:02 pm
got a bit of a nasty shock today. :shock: .....my v6 failed its mot on emissions :oops: , the garage tried their best to get it passed ,but after a bottle of fuel cleaner? and a 30minute blast up the motorway the reading hardly budged :evil: ......the sheet reads LIMITS: 0.30% vol.......my reading 0.70..........second test 0.74 ....they want me to drop it back in tomorrow to take a closer look ....is there anything i can do myself (exept pray) before opening my wallet [-o< #-o
Dolly1
Re: V6 MOT Failure Emissions
Post by Dolly1 » Fri Jan 09, 2009 9:06 pm
Hi flippa,
You could try some injector cleaner in the fuel tank,take for a FAST spin.
Only a temporary fix i know,but it might do the job,otherwise injectors out and clean them.
SARAH & LIONEL - I Used to be Citroen 2CV "DOLLY" mad but BONGO-MAD lady with not so mad husband now!
dandywarhol
Post by dandywarhol » Fri Jan 09, 2009 9:08 pm
Check the condition of the air filter??
scanner
Post by scanner » Fri Jan 09, 2009 9:13 pm
Is that the CO reading or what?
(haven't had a petrol car tested for years so not sure what it is they test for)
flippa
Post by flippa » Fri Jan 09, 2009 9:40 pm
Cheers dolly done that #-o Dandy ....air filter ?? its only been in 6 months , i could put a new one in ? i have a few (i read before you say no harm in taking the air filter out for the test?)
Scanner yes tis the CO reading :oops:
scanner
Post by scanner » Fri Jan 09, 2009 9:48 pm
flippa wrote: Scanner yes tis the CO reading :oops:
Isn't that controlled by the Lambda wotsit and if that isn't working right the CO goes through the roof.
I seem to remember bro-in-law having that prob with his Escort.
flippa
Post by flippa » Fri Jan 09, 2009 9:59 pm
i wont be doing the lambada then #-o are these sensors replaceable ? available ? cheers scanner
shaun.m
Post by shaun.m » Fri Jan 09, 2009 10:01 pm
sounds like the lambda isnt switching you could try taking it out and cleaning it but you would probably be wasting your time they can get clogged try to drive at low speed high revs lock it in first and drive at 30 for a couple of miles to the test station and see if they can test it straight away you never know
Post by Doone » Fri Jan 09, 2009 10:25 pm
Al had this on a V6 - the lamda reading was low and the CO high. The customer didn't want extra expense at that time, so (with his agreement) he unclipped the top of the airbox where the filter sits and it passed.
flippa
Post by flippa » Fri Jan 09, 2009 10:29 pm
cheers Shaun, any idea where this is located on the v6 .....not sure these guys are bongo friendly ...and i dont have access to the members area to get a look at the schematics #-o
Ron Miel
Post by Ron Miel » Fri Jan 09, 2009 10:33 pm
scanner wrote:Is that the CO reading or what?
See here: http://www.motester.co.uk/mot-cog.html. Got 10 months until ours is next due, so haven't been carefully through it yet but it looks useful
Good luck. Interested to hear the outcome, ours is a V6 too.
flippa
Post by flippa » Fri Jan 09, 2009 10:36 pm
Hi Doone thanks for the info the lambda looks favourite at the moment....should i take the air filter out ? leave the lid off the air filter housing? and also do you have any idea how i can get the correct replacement lambda sensor part no's etc :?:
shaun.m
Post by shaun.m » Fri Jan 09, 2009 10:36 pm
hi flippa not sure of its exact location havent looked at mine , but it will be on the engine side of the cat and will have flexible bunch of wires coming from it dont get it confused with the other sensor which has a hard copper type wire connected
Post by Doone » Fri Jan 09, 2009 10:44 pm
Al just left the lid off at the garage, but there's the possibility of the top sucking itself shut when the engine's revved, so you may prefer to remove the filter. Just don't drive through any lumpy air on the way there. :) Mazda main dealer will be able to supply replacement parts.
kawasaki kid
Post by kawasaki kid » Fri Jan 09, 2009 11:38 pm
When the missus old Fiesta failed the MOT on it`s emissions - the lambda was at fault - the tester said to remove the sensor and clean it with brake cleaner as when cars do low annual mileage the sensor gets clogged up with soot - cleaned it up and replaced it and sent it in for a retest and it passed. =D> Just a little tip - dont clean the sensor on a nice clean concrete path - it took about a year for the stain to fade. :oops: #-o :)
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
