Is there an easy way of simply changing my sad HORN and replacing it with a Proud and impressive HORN that people take notice of
How to improve my Horn !
It was noticed this week on several road rage occasions after being undercut , pulled out in front of on roundeebouts and general bad driving. My HORN is pathetic
Wild Women from WONGO there are none in my BONGO !!
- You've Been Bongod
Re: How to improve my Horn !
hi pilajake
try these they should sound better
http://cgi.ebay.co.uk/12v-Volt-Dual-Ton ... 240%3A1318
Excellent price,
Are they easily fitted to the Bongo without any adaptions, and has anyone on this forum use them
They look ok, and should be an easy fit, but they're not 'Air Horns'. definitely electric.
Yep just electric but they sound like air horns.Bob wrote:They look ok, and should be an easy fit, but they're not 'Air Horns'. definitely electric.
Both Miss Fixit and I have fitted them and we both enjoy a most satisfying honk when the opportunity presents itself.
I got some similar last year, easy fit, had to take out the drivers side headlight to get to the old one, mounted in the same place on the existing wiring, much better sound.
Too slow
I'm still waiting to source a train or ferry horn though
- haydn callow
I've got them fitted....lovely noise.
Well,
you need at least three air horns. The more and the larger the better.
http://www.airhorns.co.uk/?gclid=CPjyjq ... 3godOy8ADA
Lovely stuff
Lovely stuff
F Zappa
F Zappa
We had the Dukes ones on our blue bongo and we are going to fit air horns to the works bongo.
Strictly for off road use and with a seperate switch, so the MOT tester is happy. Will prob fit a loud horn instead of the standard one also. There're a lot of nutty drivers around at the moment, jumping amber lights and drifting across lanes without warning, they need a good blast to wake them up.
missfixit70 wrote:I got some similar last year, easy fit, had to take out the drivers side headlight to get to the old one, mounted in the same place on the existing wiring, much better sound.
Did you just wire up, or use the relay and a new supply form the battery?
The system appears to already have a relay in it somewhere - at least mine does.Bob wrote:missfixit70 wrote:I got some similar last year, easy fit, had to take out the drivers side headlight to get to the old one, mounted in the same place on the existing wiring, much better sound.
So all I did was add a "piggy back" positive wire for the second unit and earth both units.
Thankyou both.
Must fit these to mine. Are they behaving OK in terms of reliability Kirsty and Scanner (the horns I mean!). I only ask as we've all experienced the 'rusting spotlights from ebay' phenomenon and I'd prefer no more repeats (although I've now taken to smearing vaseline on my spotlights chromework and it seems to be doing the trick, more or less).
