Help guys I'm in the process of replacing my fan belts and air con belt. I have slacked off the alternator no probs and the fan belts have come off no probs but the air con belt is stopping them from being removed. Can anyone tell me how to slacken off the aircon belt so i can remove and replace it.
Many Thanks
Liggy
Air Con Belt Removal
Simplezzzzz
Re: Air Con Belt Removal
Check the factsheets - http://www.igmaynard.co.uk/bongo/member ... aircon.pdf should help
Many thanks Kirsty as usual you're spot on, hopefully I will be able to complete the task in hand.
Simplezzzzz
Mission now complete. Fan belts replaced used the same air con belt as it looked fairly new plus the air con belt I had didnt fit as it was it was too small to fit. Next task on the list is 2 replace my brakes pads when I have the cash too get some. Once again Kirsty many thanks for advice. Owe you a beer when we next meet up.
Simplezzzzz
No worries Darren, see you guys at Stourport if not before
