Page 1 of 2
front droplinks
Posted: Fri Dec 26, 2008 3:59 pm
by You've Been Bongod
took me 30 mins to change both sides and was very easy
now got the heavy duty ones as normal were crap
top balljoint on both were goosed
see how long these ones last
Re: front droplinks
Posted: Fri Dec 26, 2008 6:58 pm
by bigdaddycain
You have such a way with words carl!
Hope these last a bit longer than the last pair...
Re: front droplinks
Posted: Fri Dec 26, 2008 7:04 pm
by daveblueozzie
Re: front droplinks
Posted: Fri Dec 26, 2008 7:25 pm
by bigdaddycain
Mine's gotta be on borrowed time too...
Re: front droplinks
Posted: Fri Dec 26, 2008 8:56 pm
dave when you need them doin i'm your man baby
Re: front droplinks
Posted: Fri Dec 26, 2008 9:57 pm
by missfixit70
Fancy popping down to do mine Carl? - I can't be bothered
Re: front droplinks
Posted: Fri Dec 26, 2008 9:59 pm
by daveblueozzie
Re: front droplinks
Posted: Fri Dec 26, 2008 10:03 pm
no probs mate
Re: front droplinks
Posted: Fri Dec 26, 2008 10:34 pm
by missfixit70
I'll stick the kettle on then
Re: front droplinks
Posted: Sat Dec 27, 2008 2:28 am
by bigdaddycain
I'll bring the krispy kremes...
Re: front droplinks
Posted: Sat Dec 27, 2008 11:43 am
by Trouble at t'Mill
YbB, any hints you can provide? I'm thinking mainly of how to ensure the tension is off the joints when you come to undo them - how did you ensure the load was evened-out with the car jacked up?
Cheers.
Re: front droplinks
Posted: Sat Dec 27, 2008 12:19 pm
by francophile1947
Re: front droplinks
Posted: Sat Dec 27, 2008 12:42 pm
by dandywarhol
Cheers.
As long as the vans on level ground side to side they're be no load on them to allow the links to be changed.
Re: front droplinks
Posted: Sat Dec 27, 2008 1:17 pm
Cheers, Dandy. You suggesting I do them without removing the wheels - just turn them full lock for access?
I was originally wondering how to ensure a 'level playing field' after having jacked up the car and removed the wheel.
Thanks.
Re: front droplinks
Posted: Sat Dec 27, 2008 2:59 pm
by dandywarhol
You could jack up the van and put axle stands on the crossmember to keep both sides level. You'd be best to slacken off the anti roll bar clamps if the wheels are unsuspended - that will allow the a/roll bar to slip round
