Front Heating Only
jayhaytch
Front Heating Only
Post by jayhaytch » Sat Nov 29, 2008 4:04 pm
Hi; I have just returned from a great 3 month trip across Spain and France which got pretty cold towards the end. I have a full side conversion and can only guess that the converters in some way cut out the hot air supply to the rear of the cab - I cannot find a control/switch for this can anyone help with how to restore the hot air supply? Cheers.
mister munkey
Re: Front Heating Only
Post by mister munkey » Sat Nov 29, 2008 4:19 pm
Is it a Wellhouse conversion?
They block it off . . .
Post by g8dhe » Sat Nov 29, 2008 4:40 pm
On ours they extended the controls to the divider panel between the fridge and storage cupboard, low down on the inside. We sometimes catch the slider when putting something in and turn it down by mistake :-( But I'm glad its there - still needs to be turned on from the front panel of course.
solarwallace
Post by solarwallace » Sat Nov 29, 2008 5:10 pm
I don't think it's unusual as mine's the same. I'm guessing the control panel is still somewhere behind the kitchen unit...
Post by missfixit70 » Sat Nov 29, 2008 9:06 pm
Unless it's been removed. The rear heating & a/c is a seperate unit in a well behind the drivers seat, some converters remove it. If you can't find the control panel anywhere in the rear, I guess it's not there.
