My drivers side head light bulb has gone - But how do you undo it to change the bulb??
Nick
Head Lights
- dandywarhol
Re: Head Lights
Old style -
unplug the 3 wire connector
remove the rubber cap
unclip a wire hinge which keeps the bulb in
remove the bulb and replace in the reverse order - the bulb only fits in one way with the middle spade on the bulb lying horizontally.
Don't touch the new bulb with bare fingers - the oil from your skin will cause the heat to focus on that point and blow the new bulb.
Similar setup to this:
