My water pump is leaking (not look at it my self) but has anyone changed one out on their own if so any handy things i should know!!!
I there a manual for the Bongo?
has anyone changed the water pump???
Re: has anyone changed the water pump???
There is a fact sheet on how to change the water pump in the members area.
There is also a workshop manual for the diesels only, but opinions differ as to how good it is as it is a translation from Japanese with bits missing
Hi have ordered a new water pump and workshop manual hopefully it will save me a bit of money.
I've read of others on here doing hte change and not finding it hard, so good luck. Keep us posted if poss. as feedback is always handy and great to hear of successes too.
- maxheadroom
A friend and me did it in about an hour plus bleeding. One worked from the top (me) and my mate from underneath.
- dandywarhol
Make sure you get the belt tension right (2 belts) or you'll be forking out for another one sooner than you expect............
I have been running the bongo for about 400 miles after changing the water pump. All seems to be running well so far how do I know if the tension on the belts is ok?
- haydn callow
A rule of thumb is...you should be able to twist the belt on it's longest run through 90 degrees....or deflect it about half a inch midway along the longest run..
