Hazard Light Switch
Posted: Wed Nov 26, 2008 7:45 pm
by littlejobby
How do you replace the lamp in the hazard light switch? Can't find how to remove switch.
Thanks in anticipation
Re: Hazard Light Switch
Posted: Wed Nov 26, 2008 7:48 pm
by maxheadroom
with great difficulty
you can prise it out but the wires are cable tied to the back of the dash. Think I did mine when I swapped the radio and heater controls around gave me a bit more room to get in and cut the cable tie.
Hope this helps
Posted: Wed Nov 26, 2008 8:02 pm
by missfixit70
If I remember right it's got clips that need to be pushed in top & bottom, I think I used a butter knife, but it was a bit of a 'mare to get out
Posted: Wed Nov 26, 2008 8:06 pm
by littlejobby
Thank you both I'll give it a whirl
Posted: Wed Nov 26, 2008 9:58 pm
by hogggman
i managed to remove the switch,but it looked fiddly to take apart,and i left it for now
jamie
Posted: Wed Nov 26, 2008 10:09 pm
by missfixit70
the bulb is just accessed from the side I think, no need to take it apart, turn it 90 degrees with a diddly screwdriver & it should pop out.
Posted: Wed Nov 26, 2008 10:10 pm
by hogggman
thanks kirsty.i will have a look on saturday.
jamie
Posted: Thu Nov 27, 2008 4:56 am
by bigdaddycain
Curiously, the light in my hazards stopped working when the illumination in the lower bank on the heater packed up...
Sounds like i'll have fun replacing those bulbs then...
