Hazard Light Switch
littlejobby
Hazard Light Switch
Post by littlejobby » Wed Nov 26, 2008 7:45 pm
How do you replace the lamp in the hazard light switch? Can't find how to remove switch. :? Thanks in anticipation
LITTLE JOBBY
" Speaking words of wisdom Let It Be"
maxheadroom
Re: Hazard Light Switch
Post by maxheadroom » Wed Nov 26, 2008 7:48 pm
with great difficulty :D you can prise it out but the wires are cable tied to the back of the dash. Think I did mine when I swapped the radio and heater controls around gave me a bit more room to get in and cut the cable tie.
Hope this helps :D
Keep the Faith
Post by missfixit70 » Wed Nov 26, 2008 8:02 pm
If I remember right it's got clips that need to be pushed in top & bottom, I think I used a butter knife, but it was a bit of a 'mare to get out :evil:
littlejobby
Post by littlejobby » Wed Nov 26, 2008 8:06 pm
Thank you both I'll give it a whirl
LITTLE JOBBY
hogggman
Post by hogggman » Wed Nov 26, 2008 9:58 pm
i managed to remove the switch,but it looked fiddly to take apart,and i left it for now
jamie
Post by missfixit70 » Wed Nov 26, 2008 10:09 pm
the bulb is just accessed from the side I think, no need to take it apart, turn it 90 degrees with a diddly screwdriver & it should pop out.
hogggman
Post by hogggman » Wed Nov 26, 2008 10:10 pm
thanks kirsty.i will have a look on saturday.
jamie
Post by bigdaddycain » Thu Nov 27, 2008 4:56 am
Curiously, the light in my hazards stopped working when the illumination in the lower bank on the heater packed up... :-k
Sounds like i'll have fun replacing those bulbs then... :roll:
