The story begins a fortnight ago when I (Hadyns alarm actually) noticed that the coolant level was low. I topped up with water, being what I had available, & drove half an hour to my mothers house. Checking under the drivers seat I found the top hose to be ballooning & dripping coolant. I drove the 100 miles home with a careful eye on the temperature gauge...
New hoses & a radiator were ordered - the radiator just because it seemed sensible to take the opportunity to put a nice clean unobstructed one in - and a slot at the local garage booked, due to lack of time, light & the foul weather forecast. The garage is one that I've used for a few things over the last 3 years & I've always been happy with their attitude and the fact that you deal with mechanics & not reception staff.
Having dropped the Bongo off this morning I called in during the afternoon to check on progress. The mechanic (not one I'd seen around before) was in the process of bleeding the system, using the factory procedure - he quoted the procedure, so I assumed that he was following it
Andy at AVA wasn't convinced, when I phoned him to order the gold-plated gasket set & suggested that it was possible that the oil could come from gearbox oil, if there had been any leak into the radiator at that point. He suggested that it would be as well to keep an eye on things for the time being before investing in all the head work. Seems good advice to me.
Now.... When I collected the Bongo, the coolant alarm went into overdrive as soon as I turned the ignition on
Given the mechanics total lack of concern about the tank being virtually empty & the potential for airlocks, I'm forced to question the rest of his diagnosis. However, if coolant is being lost due to a failed head gasket pressurising the system, then I'm guessing that Hadyn's alarm won't give me a warning until the system has cooled & the level dropped
This mostly guesswork on my part, so I'd appreciate the thoughts of those with experience in this
