hi,
i`m thinking of changing some stuff to run from the leisure battery,now that` i`ve got it charging.what has everyone else changed over,and which fuses relate to internal lighting etc,on the fusebox?
thanks
jamie
switching internal lighting etc over to leisure battery
Re: switching internal lighting etc over to leisure battery
hi jamie,off my leisure battery i have run the cabin lights,fuse 1 10 amp,the electric blinds,passenger side fuse 6 15 amp,drivers side fuse 7 15 amp and the cigarette lighter,mirrors and radio fuse 8 15 amp. this fuse layout is for models up to sept 01 hope this helps.
i chose not to choose life ....i chose a bongo instead
Forgive me if I misunderstood this, but didnt your conversion include a leisure battery and split charger? If so, what is it running - I would have thought it was common practice to run lights and blinds, fridge etc off the leisure battery anyway
If not though, it really is quite straight foward to patch into these items on the fusebox - plenty of instructions and photos on here somewhere.
