To stop a drain on the battery through the radio I decided to cut the "battery" (yellow) feed at the back of the radio (which allows the radio to play without the ignition) and just leave the "ACC" (red) feed to use the radio with the ignition on.
I discovered that both ACC and Battery feeds need input for the radio to work, so I had to splice them together to run off the ACC.
So now I have a completely dead radio until the ignition is on (first position).
But, now I can only operate the blinds with the ignition on !
Other features that share the circuit (No 1 fuse drivers seat area) ie the interior lights, central locking are all still working OK.
How can cutting a wire behind the radio have this effect when just uplugging the radio (temp solution for the last week) didn't ?
Confused
Paul
