Manifold stud
davylaa
Manifold stud
Post by davylaa » Wed Oct 08, 2008 6:53 pm
Well at last got someone to replace broken manifold stud. While he was at it he changed the manifold gasket. It was his first time and looked exhausted when I picked it up. All running well. No more annoying screaming in first gear. Charged me £148 plus vat. What do you think? :D :D
dandywarhol
Re: Manifold stud
Post by dandywarhol » Wed Oct 08, 2008 6:56 pm
Glad you got it sorted - I changed my stud in under an hour - maybe he had problems............................. :?
davylaa
Re: Manifold stud
Post by davylaa » Wed Oct 08, 2008 7:03 pm
dandywarhol wrote:Glad you got it sorted - I changed my stud in under an hour - maybe he had problems............................. :?
Did you change the metal gasket as well. He said he had to take off alternator, turbo, loads of pipes etc. Maybe I was fiddled. Oh well live and learn.
Re: Manifold stud
Post by haydn callow » Wed Oct 08, 2008 7:09 pm
Managed to fix mine without replacing the gasket. As Dandy says about an hour. If he did all you say then I would say that was fair. 4 hours @ £35......probably won't take that long now he knows how to go about it in future.
platty345
Re: Manifold stud
Post by platty345 » Wed Oct 08, 2008 8:42 pm
Hi davylaa, I had the same prob as you also same result, Got mine done at wheelquick in wigan ,they also hate doing them,
price you paid is about right.
Heaven driving it without the noise.
dandywarhol
Re: Manifold stud
Post by dandywarhol » Wed Oct 08, 2008 9:07 pm
I didn't replace the metal gasket - because it is metal, not fibre and most likely to withstand the blowing - maybe I was lucky :)
davylaa
Re: Manifold stud
Post by davylaa » Thu Oct 09, 2008 7:40 am
platty345 wrote:Hi davylaa, I had the same prob as you also same result, Got mine done at wheelquick in wigan ,they also hate doing them,
Thanks for info. Feel a bit better about it now knowing someone else paid similar. :)
Re: Manifold stud
Post by mikeonb4c » Thu Oct 09, 2008 1:58 pm
davylaa wrote:Well at last got someone to replace broken manifold stud. While he was at it he changed the manifold gasket. It was his first time and looked exhausted when I picked it up. All running well. No more annoying screaming in first gear. Charged me £148 plus vat. What do you think? :D :D
I think that price is fine (good in fact). Not ruinous money and it sounds like one of those jobs that may go well but can go badly. And if the Bongo and the job was strange to them well, at least they got it done and its behind you now =D>
davylaa
Re: Manifold stud
Post by davylaa » Fri Oct 10, 2008 12:10 pm
Cheers for your comments.
