Well, it looks like the dreaded has finally happened to our Bongo. My wife returned from a family trip with water blowing out of the header tank.
The temp gauge was OK but the cooling system was pressurised.
I’m going to fill the system tonight and bleed it just to make sure. I’ll also check to see if any smoke comes out when I start her up tonight and also check to see if there are any other leaks on the cooling side of things that may be causing air to get in the system.
However, I’m pretty sure the gaskets gone as I’ve seen it all before with some of the old wrecks I’ve driven.
So, how hard is the head gasket to replace on a diesel?
How much time do I need to allow for the job and will I need any specialist tools?
I’ve rebuilt mini and old ford pinto engines so I’m sure I can cope with the removing the head and changing the gasket, but, I’m just a bit worried about having to mess with the turbo and injector bits …
I’ve got to the change the gasket myself as my wife is on maternity leave and I need to save the cash as I’m due to be made redundant in January.
