glow plugs
glow plugs
Hi all,the bongo's a pig to start on the first start of the day whether it be morn,noon or night.Its fine at all other times,glow plugs are getting a 12volt feed for 10 secs although light goes out after 5secs.So whipped the plugs out for test & found one not glowing,has anyone ever changed a single plug or is it advisable to change as a set? She's up for sale so trying to keep costs to a minimum,thanks in advance
- westonwarrior
Re: glow plugs
Well I have to say if some one was to come and view it and it struggled to start would they buy it?
Best bet is change them and then it will be a easier or faster sale and you can point it out as a selling point
Re: glow plugs
thanks weston for the reply,did indeed change all the plugs & started beautifully.Now considering selling the audi & keeping the bongo
Re: glow plugs
Oh one other thing,whilst i was digging around i thought i'd check the fuel bango filter which proved rather elusive.Took the pipe off at the front of the pump but here there was only a spring? Can only assume the filter is at the back of the pump,the return? Any helpful pics anyone?
- westonwarrior
Re: glow plugs
Im looking for a run around, £250 for the audi? as its a pretty boring car ,too low no kitchen or beds etc
Re: glow plugs
wes 68 wrote:Oh one other thing,whilst i was digging around i thought i'd check the fuel bango filter which proved rather elusive.Took the pipe off at the front of the pump but here there was only a spring? Can only assume the filter is at the back of the pump,the return? Any helpful pics anyone?
Have a look here for Banjo Filter
http://www.igmaynard.co.uk/bongo/member ... rainer.pdf
Sparky
Re: glow plugs
thanks fellas,read a few previous posts & the filter is located under the spring i took out
,so near yet so far! Weston the audi's an 02 cabriolet so worth at least twice that!Will bear you in mind tho if i get no other offers
- westonwarrior
Re: glow plugs
Sold for £500 then
but I want new mats
but I want new mats
