Fault codes...
WISHIHADABONGO
Fault codes...
Post by WISHIHADABONGO » Thu Oct 02, 2008 11:56 am
Anyone know how to clear fault codes from the ECU?
Re: Fault codes...
Post by Ian » Thu Oct 02, 2008 12:17 pm
Remove the wire from the negative terminals for at least 20 seconds.
Click on the brake pedal and release.
Re-connect negative battery terminal.
Start engine, and run for 3 minutes at 2,000 rpm idle.
