warning light hold
carr
warning light hold
Post by carr » Sun Sep 28, 2008 6:48 pm
Help just bought bongo had it 6 days been on a run and the hold light came on what is this? i switched off then restarted and it went off later on the same day it came on again i did the same and it cleared I need to know what this means please, I got three months warranty on engine and gearbox so I would like to Know before I go back to the dealer
THANKS
Tony
Re: warning light hold
Post by francophile1947 » Sun Sep 28, 2008 6:52 pm
Welcome to the madhouse :D - don't forget to put your location in your profile, cos' it helps us to help you (local help).
Are you sure you're not just catching the "Hold" button on the gear lever - very common amongst new users
mikexgough
Post by mikexgough » Sun Sep 28, 2008 7:20 pm
I agree, make sure you haven't knocked the hold button, enjoy your Bongo
mister munkey
Post by mister munkey » Sun Sep 28, 2008 7:29 pm
Its only a problem if the Hold Light flashes.
Assuming its not, all is well.
Warm welcome.
8)
carr
Post by carr » Sun Sep 28, 2008 7:33 pm
mikexgough wrote:I agree, make sure you haven't knocked the hold button, enjoy your Bongo
THANKS
Tony
Post by mikeonb4c » Sun Sep 28, 2008 7:43 pm
I was always knocking it on in the early days. Usuall by pressing my arm accidentally against it while reaching past the gear lever into the centre cubby :oops:
carr
Post by carr » Sun Sep 28, 2008 7:45 pm
mister munkey wrote:Its only a problem if the Hold Light flashes.
Warm welcome.
8)
THANKS
Tony
aitch
Location: in a place far, far away, well Somerset for now!!!
Post by aitch » Sun Sep 28, 2008 10:15 pm
welcome to the forum and to ownership.
Post by Bob » Sun Sep 28, 2008 10:18 pm
Welcome aboard Carr, agree with Mr M, if it flashes is is a diagnostic code, if not probalby doing what we all did. :D
Post by bigdaddycain » Mon Sep 29, 2008 10:34 am
mikeonb4c wrote:I was always knocking it on in the early days. Usuall by pressing my arm accidentally against it while reaching past the gear lever into the centre cubby :oops:
Same here mike for the first few weeks of ownership...I was convinced there was an intermittent fault till i realized what i was inadvertantly doing.... :oops:
LEEANGE
Post by LEEANGE » Tue Sep 30, 2008 1:09 pm
Warm welcome.
8)
:? HI THERE, JUST BOUGHT MY 1ST BONGO ABOUT 3 WKS AGO. LOVE IT!!!
MY HOLD LIGHT WAS FLASHING THE OTHER DAY BUT HAS STOPPED NOW.
WOT DOES THIS MEAN????
Post by mikeonb4c » Tue Sep 30, 2008 1:14 pm
Warm welcome.
8)
Needs watching very carefully. Is it under guarantee?
Oh and welcome! 8)
nfn
Post by nfn » Tue Sep 30, 2008 4:33 pm
Leeange,
You may still have a fault code stored in the computer even though the hold light has stopped flashing. I would recommend following the fault code fact sheet directions in the members area to see if you get a fault code. If so, you should be able to get it taken care of under warranty. Flashing holds are often caused by sticking solenoids in the trans. Best to try to get the code as soon as possible,
johnd2000
Post by johnd2000 » Tue Sep 30, 2008 9:16 pm
Now I'm worried!
I had a stuck HOLD the other day. I'm pretty sure I hadn't hit the button, and hitting the button didn't clear it. It stayed on for about 10 minutes, then went off. A little later it flashed and the rev counter kept cutting in and out for a few minutes. The engine was running normally and there was no apparent loss of power or anything else to indicate a serious problem. The rest of the way home (another 40 miles or so) she ran perfectly. As she did the next day.
Given that she's well out of warranty, what sort of things COULD it have been? [-o<
Post by francophile1947 » Tue Sep 30, 2008 9:20 pm
johnd2000 wrote:Now I'm worried!
Have a look at this thread http://www.igmaynard.co.uk/bongo/forum/ ... er#p220524
