Hi there
does anybody know if you can change the seals on the injector pump and how easy is it to do or is it a garage job.
Oggy
injector pump seals
- The Great Pretender
Re: injector pump seals
This is a 'how long is a piece of string' question.
It depends on how mechanically minded you are, and how far you want to go. The rear is easy, the front side one too, the one at the back a pain. The front seal requires new timing belt.
So how long is your string.
Or you could go all the way
http://www.vwdieselparts.com/forum/view ... wn&start=0
To infinity and beyond
