I have no Horn!!!
Jolly Rogers
I have no Horn!!!
Post by Jolly Rogers » Wed Sep 17, 2008 3:43 pm
My horn has stopped working, I have checked the wires they seem fine and checked the fuses. Anybody know which fuse is for the horn? [-o< [-o< [-o<
Re: I have no Horn!!!
Post by Doone » Wed Sep 17, 2008 3:48 pm
On models up to Sep 2001, it's a red 10amp one, 5th from the left on the top row of interior fuses. Edward had a similar problem recently, so if replacing the fuse doesn't fix it, have a look at his post: http://www.igmaynard.co.uk/bongo/forum/ ... =horn+fuse
Jolly Rogers
Post by Jolly Rogers » Wed Sep 17, 2008 3:52 pm
Cheers for the speedy response. Changed the fuse still no horn.Defo not the fuse must be a loose connection somewhere #-o
the janner vanner
Post by the janner vanner » Wed Sep 17, 2008 7:17 pm
unfortunatly i still have no horn, i think that when i removed the washer bottle i've knocked a wire connection, as i have a loose blue wire connected to the horn wiring with the other end hanging lose and it looks as if it has broken off somewhere. I have after market twin horns and i'm hoping that one of the Bongos attending the Looe bash has the same type of horns as mine, so as i can compare wiring
The Janner Vanner
sparkymik
Post by sparkymik » Wed Sep 17, 2008 8:46 pm
Jolly Rogers wrote:Cheers for the speedy response. Changed the fuse still no horn.Defo not the fuse must be a loose connection somewhere #-o
Have you tried putting 12v directly onto the horn this would prove the horn one way or tother?
Sparky
Jolly Rogers
Post by Jolly Rogers » Thu Sep 18, 2008 7:49 pm
Have managed to trace a break in the cable [-o< Hopefully that's causing the problem. Will try and fix at the weekend.
lizard
Post by lizard » Thu Sep 18, 2008 8:47 pm
Can you here the relay click when you press the horn button?
I can't help my self:... :lol: :lol: :lol:
F Zappa
Jolly Rogers
Post by Jolly Rogers » Thu Sep 18, 2008 9:06 pm
No click can be heard :?
lizard
Post by lizard » Thu Sep 18, 2008 9:29 pm
Jolly Rogers wrote:No click can be heard :?
This is a simple wiring circuit of a horn installation, might help.
Is the break between the button and the relay?
On the Bongo the circuit is not powered through the ignition switch and the fuses are not shown.
F Zappa
Jolly Rogers
Post by Jolly Rogers » Thu Sep 18, 2008 9:34 pm
It is just by the horn.
lizard
Post by lizard » Thu Sep 18, 2008 9:43 pm
The relay should click even if the horn is not working, Check all the earth cables the horn one first.
A test between an earth point and the horn feed cable with the horn disconnected with a meter/lamp will tell if the relay is working and the cable from the relay is ok.
F Zappa
Jolly Rogers
Post by Jolly Rogers » Thu Sep 18, 2008 9:51 pm
Cheers . :( I dont have a meter to test it though :(
