Dead alternator - again!
Post by missfixit70 » Mon Sep 15, 2008 11:17 pm
Was out and about today, just heading into Dorchester & the speedo died, then the rev counter dithered about & died too, I parked up for 5 minutes while I popped into hospital (not for the bongo [-X ), then when I came out it wouldn't turn over. Checked starter battery voltage & it was down to 11.something, luckily LB was fully charged so I disconnected the positive & jumped it across to the SB & it fired up ( thank god for the LB)- but there was no charge going into the battteries :( There were no indicators up on the dash as there were when the alternator went before :roll:
I managed to get home without the fuel solenoid valve closing [-o< , checked all the fuses, everything seemed ok, no voltage coming out of the alternator, but it was receiving field voltage, so I popped down to Chris Putt who I got the recon alternator from, he checked & confirmed it was goosed, turns out it was 3 days away from being out of guarantee =D> :D . On the way down to him the glow plug light started flashing, which I guess was telling me I was just about to lose the fuel solenoid voltage.
15 minutes later, new one fitted & another years guarantee :D - hopefully this one lasts a bit longer [-o<
I have no idea why it went, it was charging fine a few days ago as I checked it when I was trying to find my LB current drain (stereo - cheers guys :wink: switch fitted in the ignition supply wire).
You've Been Bongod
Re: Dead alternator - again!
Post by You've Been Bongod » Mon Sep 15, 2008 11:24 pm
glad you sorted kirsty although you were lucky about warantee :wink:
daveblueozzie
Post by daveblueozzie » Mon Sep 15, 2008 11:25 pm
About time you got a bit of luck , =D> :D 3 days to go ,wonder how they time it ? :lol:
Lost without my Bongo.
You've Been Bongod
Post by You've Been Bongod » Mon Sep 15, 2008 11:29 pm
daveblueozzie wrote:About time you got a bit of luck , =D> :D 3 days to go ,wonder how they time it ? :lol:
i would say thats pretty easy give you 3,6 0r 12 months after that tough titty :lol:
Post by missfixit70 » Mon Sep 15, 2008 11:31 pm
Now if I was a pessimistic cynic.......
Oh wait - I am :lol:
I'm sure it was a one off, this guy has been there for years & years, I don't think he'd survive long selling dodgy crap :wink:
You've Been Bongod
Post by You've Been Bongod » Mon Sep 15, 2008 11:33 pm
i wasnt sayin he was dodgy but some garages are
Post by mikeonb4c » Mon Sep 15, 2008 11:49 pm
Good it happened now than when out of guarantee and you were off to SW Bash. Must ask you by the way Kirsty. I've been trying to find your thread on rust near where the aircon drips water out below the vehicle. I discovered a significant, but localised bit of corrosion on mine while relaxing underneath it yesterday. It was at front end of n/s 'chassis' side member just where there is a triangular box section that joins to a cross member. I've taken pics and will post a thread when I get a moment (!) but thought I'd ask you first. Seems this could be a 'type weakness' worth alerting (again) owners and prospective purchasers to.
Hope you are keeping well.
Mike 8)
Post by Bob » Tue Sep 16, 2008 8:43 am
Hi Kirsty, stroke of good luck being still in waranty, not how it normaly works. :D
Mike, could the rust be caused by acid overflowing from the battery, possibly caused by over filling, or over charging?
Nevets
Post by Nevets » Tue Sep 16, 2008 9:42 am
Quite good of him to give you another 12months on the alt =D>
Most factors and garages would only let it run til the end of the warrenty period(the magic 3days) [-o<
Nice one Kirsty :lol:
I am the only bongo in the village.......(not anymore there's two of us now "Damn it)
Post by mikeonb4c » Tue Sep 16, 2008 1:02 pm
Bob wrote:Mike, could the rust be caused by acid overflowing from the battery, possibly caused by over filling, or over charging?
I thought of that, but this is/was the non battery side until the LB was fitted. There is a boxed secion above it with wiring conduit (at least I think it's wiring though can't see inside the conduit) going into it and wasn't feeling like lifting the engine covers to trace what it might be connected with. I'm going to check out Kirsty's 'rusty cills' thread to see if its the same prob she came across and I'll try and post pics tonight.
Distilled Waters Run Deep
Post by Distilled Waters Run Deep » Tue Sep 16, 2008 5:30 pm
-Similar symptom, Kirsty, with a newly replaced alternator & I found the plug which connects the sensor under the cowl, (just behind the handbrake) was loose. In spite that this may be what goosed the alternator, the very very nice people at http://www.startermotor-alternator.co.uk/ replaced it for me under warranty.
Freda AFT: Haydn/Mason alarms + engine head temperature sensor.
Moto Guzzi California Jackal X reg
