Front Brake anti rattle shim
IanEagland
Post by IanEagland » Fri Sep 12, 2008 12:24 pm
Does any one know where to get a new set of the thin spring clips for the front brakes. I think they may be called shims.
Regards
You've Been Bongod
Re: Front Brake anti rattle shim
Post by You've Been Bongod » Fri Sep 12, 2008 12:27 pm
hi ian ,
where are you from mate as you ain't put on you profile :wink:
you could try a brekers or look on ebay as there are 3 bongo's bein broken for spares
here are their ebay id names for you :wink:
nmafigaros
bongocampa
topazthedog
hope this helps
Veg_Ian
Post by Veg_Ian » Fri Sep 12, 2008 12:48 pm
Do you mean the spring clips that hook into the holes on the pads and push the pad off the disc or the metal shims that fit on the pads?
IanEagland
Post by IanEagland » Fri Sep 12, 2008 2:07 pm
Located in Lyme Regis. Now in profile.
The metal shims that fit on the pad. I had a horrible noise and my local garage found a broken shim caught in the brake assembly.
They took it out but now I get a squeak from the brakes all the time until I apply them.
Regards
Veg_Ian
Post by Veg_Ian » Mon Sep 15, 2008 7:45 am
Try applying a smear of copperslip to the back of the pads
