Heater Control not working
hovis2130
Post by hovis2130 » Mon Sep 08, 2008 11:41 am
Hiya
Our heater controller has packed up, settings 1-4. However the aircon light works from 1 -3 but we have no air coming through the vents #-o
Over the weekend we looked at the brushes which were ok and cleaned the parts and put it all back together as described in the factsheet - still not working. However this am I have slide the cold and hot slider to hot and you can feel a slight warm coming though but not through the controller speeds - does anyone have any ideas as up to 2 weeks ago the heater and aircon were working lovely. [-o< p.s we have also checked the fuse - that is working ok !
Re: Heater Control not working
Post by francophile1947 » Mon Sep 08, 2008 11:58 am
Have a look at this http://www.igmaynard.co.uk/bongo/forum/ ... er#p227263. The resistor is a common problem and easily fixed - there are loads more threads on the subject if you search for "heater AND resistor".
brorabongo
Post by brorabongo » Mon Sep 08, 2008 12:32 pm
Can you hear the fan running? if so it might be the linkage down by your left foot on the drivers side has become detached.
See here....
http://www.igmaynard.co.uk/bongo/forum/ ... er+control
ボンゴの激怒 pictures
