Lowered suspension
Jolly Rogers
Lowered suspension
Post by Jolly Rogers » Fri Sep 05, 2008 8:09 pm
How easy is it to change over the suspension springs? I have managed to get hold off some lowered springs :roll:
mister munkey
Re: Lowered suspension
Post by mister munkey » Fri Sep 05, 2008 8:11 pm
Easy peasy - allegedly. Around 20 mins per corner.
BDC is a good one to ask.
If you find another set, give me a shout!!
scanner
Post by scanner » Fri Sep 05, 2008 8:31 pm
Are they proper lowered ones or just cut down standard ones?
If you get them changed, can I borrow the standard ones to see about getting some lowered ones made up?
Jolly Rogers
Post by Jolly Rogers » Fri Sep 05, 2008 8:55 pm
I think they are proper lowered springs, How can I tell?
scanner
Post by scanner » Fri Sep 05, 2008 11:26 pm
Jolly Rogers wrote:I think they are proper lowered springs, How can I tell?
I think they should have the same number of coils as the originals and proper flattened off ends, not coils that just stop suddenly in mid air (If you understand what I mean).
cheffy34
Post by cheffy34 » Fri Sep 05, 2008 11:30 pm
Mine are a pretty light blue colour the standard ones i took off were black don't know if they are all black did notice a big diff when i stood em both together standard and non. Took me longer than 20 mins per corner ran into a stumble on the fronts and had to whip one of the front struts down to me mates garage to finish, I was worried about the clearance cos some mugger told me it would drop it by 70 mm but no, i fear 50mm is more like it, just right but still leaves a fair arch gap :( Top tip i went and bought meself an inpact bar after breaking two ratchets with an extension pole on them, i keep it in the van now with a socket for undoing the wheel nuts cos the standard wheel nut one doesn't fit my nuts :roll: :D :!: :!:
scanner
Post by scanner » Fri Sep 05, 2008 11:36 pm
I'm still looking for a standard set so I can check the viability of having a batch of proper lowered ones made up.
If anybody can lend me a set I'd be grateful.
cheffy34
Post by cheffy34 » Sat Sep 06, 2008 12:07 am
Sorry scanner no can do :roll: i'm affraid they went in freeadds ages ago got nearly as much for them as i paid for the lowered ones :D worth while really, i was shocked that no one on here bid on the ones i bought only paid £58 inc front struts shocks rear arms, postage and an adjustable pana.......? what ever it called bar :roll: If i still had them you'd be welcome :roll: I may even get round to fitting the rear bar at some point :roll: :roll:
Jolly Rogers
Post by Jolly Rogers » Sat Sep 06, 2008 1:50 pm
Just had a look and they are light blue :D , So just got to get them off the donor vehicle and put on mine :lol: :lol: I love it when a plan comes together.
Post by bigdaddycain » Sun Sep 07, 2008 1:56 am
Post some pics on "pimp" when you get it done JR? :wink:
Jolly Rogers
Post by Jolly Rogers » Sun Sep 07, 2008 8:55 am
Will do :D . All i need now are Chrome mirror covers :lol:
apssrf
Post by apssrf » Wed Sep 17, 2008 6:36 pm
Does lowering the suspension reduce the Bongo height by 5cm then? The reason i ask is because this would mean we could get our Bongo in our garage and also it would look good into the bargain!
Mike Jill and Emily
Post by Mike Jill and Emily » Thu Sep 18, 2008 8:08 am
I lowered mine last Saturday - it looked great ---- unfortunately they went back to normal when I took the 10 bags of gravel out of the back :shock:
Post by bigdaddycain » Thu Sep 18, 2008 10:51 am
:lol: :lol: :lol: My driver's side gets lower still...each and every time i get in the bongo! :lol:
Post by bigdaddycain » Thu Sep 18, 2008 10:55 am
mister munkey wrote:Easy peasy - allegedly. Around 20 mins per corner.
I wish i could shed some light here...I can't though, i was owed a "freebie" job at the garage that fitted my lowering springs,i simply dropped my bongo off in the morning, then picked it back up that afternoon.
I asked how much it WOULD have cost me, they reckoned about £20-£25 per corner. Easy job they said.
I had the job carried out by Willis motors in Warrington. Their bongo expert is a good friend of mine called kev. :wink:
