EGR blanking
oggy
EGR blanking
Post by oggy » Wed Sep 03, 2008 4:04 pm
Hi all
does anybody know where i would get an EGR non return valve from as local mecnanic says mine is not there, looks like its snapped off. He says thats why i am having the black smoke problem that i posted last week, can anyone help. [-o< [-o<
Oggy
dobby
Re: EGR blanking
Post by dobby » Wed Sep 03, 2008 4:14 pm
If it's a little plastic thingy then no one is too sure what they do (I think) but they can be bodged by inserting a small piece of pipe either inside or outside of the break. I fixed mine with a Biro refill. There's a post on the forum somewhere....try this link http://tinyurl.com/3474fu
Good luck
Re: EGR blanking
Post by Bob » Wed Sep 03, 2008 8:10 pm
Probaly your best bet is to get an EGR blanking kit from Allans, Plymouth, for about £12. Apparently easy to fit, and on my 'To Do' list.
dobby
Re: EGR blanking
Post by dobby » Wed Sep 03, 2008 8:19 pm
The kit's are good, I've fitted one but in the process either broke or discovered the the broken plastic thingy. I think this may be what your mechanic is referring to?
Re: EGR blanking
Post by Doone » Thu Sep 04, 2008 9:53 am
If it' is the part that dobby is referring to, Al has seen dozens come in from Japan with that part broken. It doesn't usually cause a black smoke problem?
Here's the instructions dobby gave when he fixed his, if it sounds like the same part, you're sorted:
I reamed the inside of the valve and the broken bit out to a diameter that would receive a piece of Biro refill pipe to act as stub/spigot and then carefully glued the two parts together, checking that the valve still worked. Wrapped it in duct tape to add a bit of support.
