tackling the tappetty engine over the winter
hogggman
Post by hogggman » Tue Sep 02, 2008 8:38 pm
hi all,
i don`t know who remembers,but i have the tappetty v6,and have pretty much narrowed it down to worn camshaft or sticking hydraulic lifters(it was stood for about 10 months after importing after the guy realised he couldn`t get it sva`d-i bought it and had it converted to a camper,then registered it myself)another forum member phoned me once to offer advice when i read that he replaced valve seals for someone.i wondered whether it would help my bongo,but he said only if it as burning oil.it does produce a small amount of white smoke on startup,uses a tiny amount of oil,loses no coolant at all,and has carried us for 4,000 miles with no problems.it returns up to 32mpg on a steady run.
now that our main holidays are over for this year,i plan to investigate further.i have tried in vain to find the correct engine manual,and the closest i have is the mazda mpv 2.5 v6 petrol dohc.
all i really need is info on the timing alignment,and torque settings for the tensioner,camshaft and other important bits.is there anywhere that i can get this,or would anyone be willing to photocopy/scan anything that you ave,to help me?i`d be willing to pay,of course.
thankyou
jamie
Re: tackling the tappetty engine over the winter
Post by haydn callow » Tue Sep 02, 2008 9:28 pm
have recently bought a diesel Mondeo which was driving me nuts with the valve lifters tapping away...thought I go for the easy option first and bought a bottle of oil treatment formulated for noisy lifters...about £6.50 from Halfords...It worked and within an hour noise gone and hasn't returned....Was unbearable when cold and still there untill really warmed up.
Post by mikeonb4c » Tue Sep 02, 2008 11:15 pm
Good luck with it. 32mpg is unheard of with a V6 - astounding if accurate and enough to make one get ones thinking cap on 8)
Post by teenmal » Wed Sep 03, 2008 12:31 am
Hi Hoggy,if you are getting 32mpg with a 2.5 v6 petrol,and the valve clearance noise is not severe I would tend to leave well alone.Try some wonder oil as some one has mentioned.
What ever you do all the best.
Mal..
dandywarhol
Post by dandywarhol » Wed Sep 03, 2008 8:58 am
32 mpg - good stuff - maybe we should all loosen our valve clearances a bit to see if our guzzlers can get somewhere near that.......................
manners
Post by manners » Wed Sep 03, 2008 4:36 pm
Iam only getting about 25 mpg mix 70% motorway 30% A&B roads not to heavy on the right foot either!
Nevets
Post by Nevets » Thu Sep 04, 2008 10:33 am
I recall Mr H trying various oil additives and oil changes..
Give us a shout if needed..
Cheers Steve..
P.s How's mini Hogggman and his plasterd arm???
I am the only bongo in the village.......(not anymore there's two of us now "Damn it)
hogggman
Post by hogggman » Thu Sep 04, 2008 6:14 pm
hi steve,
yes,indeed i have tried various additives in the past.i will do one more engine flush,then oil and filter cahange and probably leave it at that.i will investigate the timing belt,as the guy i bought it from assured me it had been done,but..............you never know!!!!
junior hogggman is now in plaster from hand to armpit,and is due back at the qmc on monday.if all is well he stays in plaster for 6-8 weeks,but if not going well he may have to have it pinned.
thanks
jamie
Post by mikeonb4c » Thu Sep 04, 2008 7:56 pm
Sorry to hear about Junior - hope he mends quick. Send him our best wishes for a speedy recovery. At least he's not missing a great summer :roll:
aitch
Location: in a place far, far away, well Somerset for now!!!
Post by aitch » Thu Sep 04, 2008 10:03 pm
Years ago (mid 1970's) I used to work on Hillman Imps and they all had noisy tappets with an overhead cam which had to have shims put in of various thickness to stop the tappets ratteling, quite a complecated process, I don't know it the Bongo V6 is OHC but if so this could be quite a complcated process involving microcromiters etc. if it's working I would suggest IMHO leave well alone.
cheffy34
Post by cheffy34 » Thu Sep 04, 2008 10:33 pm
32 to the gallon :shock: :shock: i swop ya my v6er :!: you get a quiet one and i can stop my love affair with the petrol pump, prob solved :D :D :wink:
by the way good luck to junior horrid bein in a cast, i was in for 12 weeks, plate 10 screws and a couple of painfull ops wouldn't wish it on anyone, then you get the arthritis that goes wiv it afterwords and all in the name of a few bevvies to many #-o
