No horn
Bigblackbeastiebobbongo
No horn
Post by Bigblackbeastiebobbongo » Sat Aug 23, 2008 11:19 pm
HELP! The horn aint working on the beastie. Any ideas?
brorabongo
Re: No horn
Post by brorabongo » Sat Aug 23, 2008 11:32 pm
Easy things first, like the fuse, then relay ( is it clicking ), then the horn itself, by first checking if you are getting 12V at the connections.
I have read on here about others who had the same problem, so fingers crossed they read this and give you a few pointers.
All the best.
ボンゴの激怒 pictures
Re: No horn
Post by missfixit70 » Sat Aug 23, 2008 11:33 pm
The horn is behind the driver side headlight if you need to get to it, but as Brora says, check the obvious first.
M 80NGD
Re: No horn
Post by M 80NGD » Sat Aug 23, 2008 11:36 pm
My horns are central,behind the bumper!!!!!! :!:
My Names Bond......Lee Bond!!
Re: No horn
Post by missfixit70 » Sat Aug 23, 2008 11:40 pm
Guess they're not all the same then, different years maybe? unless yours are replacements? I had to take the headlight out to replace mine.
M 80NGD
Re: No horn
Post by M 80NGD » Sat Aug 23, 2008 11:47 pm
Hi Kirsty,mine may be replacements,as I've got two!! My bongo came from Japan with a full bodykit and lots of mods,so these may not be original!? :o Lee.
Re: No horn
Post by missfixit70 » Sat Aug 23, 2008 11:50 pm
That may explain it then :wink: Sounds like you need to get some photos up in "Pimp My Bongo" 8)
M 80NGD
Re: No horn
Post by M 80NGD » Sun Aug 24, 2008 12:02 am
Hi Kirsty, I will post some photos when I know how!! I own a green/silver 1995 bongo with full bodykit and full conversion. When I bought it,it was 3 inch lower but I had the proper suspension put on when it was converted to a full camper. It has a larger diesel pump fitted to make it faster!! (done in Japan!)so does about 19 to the gallon :!: The best bit though,the registration plate I bought is:- M 80NGD,so when doctored is:-M 80NGO,cheers,Lee. :wink:
mick
Re: No horn
Post by mick » Sun Aug 24, 2008 12:11 am
Hi BBBBB
I had the same problem. There is a cassette in the boss of the steering column. It is a ribbon cable which is wound so that when the steering wheel is turned, the ribbon unfurls. It also carries the signal for the airbag (if fitted).
Its worth checking continuity of the ribbon cable. I had to replace mine.
M 80NGD
Re: No horn
Post by M 80NGD » Sun Aug 24, 2008 12:17 am
Thanks Kirsty,I don't even know how to send a PM!!! :oops: :oops: sorry :!:
brorabongo
Re: No horn
Post by brorabongo » Sun Aug 24, 2008 1:28 am
I thought most bongos have two horns? (Different tones)
Mine are quite loud, and are originals (I think), yet I hear folk moaning about how rubbish their horns are. :?
ボンゴの激怒 pictures
Re: No horn
Post by teenmal » Sun Aug 24, 2008 9:29 am
Hi,the bongo is normally fitted with two horns (hi-tone and low_tone)
Someone a wee while back had a horn problem,turned out to be no horns, just the wire.
Mal..
Re: No horn
Post by Simon Jones » Sun Aug 24, 2008 9:45 am
teenmal wrote:Hi,the bongo is normally fitted with two horns (hi-tone and low_tone)
Mal..
I don't believe that is the case. Certainly mine & the others I have seen only have one rather weedy unit fitted behind the headlamp. I've now fitted a pair of Fiamm horns from a Saab.
scanner
Re: No horn
Post by scanner » Sun Aug 24, 2008 11:42 am
Mal..
Mine only had a single "Meep" Meep" one as well - looks like some Japanese owners got fed up and went the aftermarket fitment route as well.
brorabongo
Re: No horn
Post by brorabongo » Sun Aug 24, 2008 2:34 pm
ボンゴの激怒 pictures
