speedo is out
davylaa
speedo is out
Post by davylaa » Sat Aug 23, 2008 3:06 pm
Got the speedo out. Anyone know how to remove the chip. I dont even know what it looks like.
Cheers [-o<
westonwarrior
Re: speedo is out
Post by westonwarrior » Sat Aug 23, 2008 3:23 pm
the chip is wired to the back with 1 wire from the loom going through it
davylaa
Re: speedo is out
Post by davylaa » Sat Aug 23, 2008 3:36 pm
Thanks Rob. Do I just cut the wire and take it out?
Cheers Dave
westonwarrior
Re: speedo is out
Post by westonwarrior » Sat Aug 23, 2008 3:40 pm
the wire to the input i think has been cut and wired into the chip so you need to reconnect that wire and just unscrew the other wires replacing the screws in the unit
the chip should then be free
davylaa
Re: speedo is out
Post by davylaa » Sat Aug 23, 2008 3:41 pm
Thanks again Rob
davylaa
Re: speedo is out
Post by davylaa » Sat Aug 23, 2008 4:45 pm
westonwarrior wrote:the wire to the input i think has been cut and wired into the chip so you need to reconnect that wire and just unscrew the other wires replacing the screws in the unit
All done. Just gotta but faceplate.
Thanks a lot
Dave
