Also where can i get one please??
Cheers,
Lloydy,
mine works great on both vehicles,i woudn't be without one.Lloydy wrote:Cheers Paul,
Have seen some of your other entries re. this item and seems to be worth while.
Is yours still functioning well?
Lloydy
cabte wrote:Hi Lloydy
I have a mson alarm works a treat![]()
If you notice your temp will or should read about 11 clock and barely move .
The mason alarm gives a better reading ( good true temp reading ) and will let you now in good time if the Bongo is over heating.
You can set the alarm to your bongos requirments.
The best way to do it is set the Mason to 0 then drive the bongo to running temp by this time the alarm will be sounding..
set the alrm by turning the dial till the alrm just stops,
Then find the bigest hill to drive up to put the engine under strain( not to much ) the alarm should start to go off again as the temp will rise .
now increas the alarm again till it stops.
Mine runs on NO 4..
all done
Good thing to have ..
paul9 wrote:do a search for mason alarm,and it should give you a link to his website.
http://www.townace.plus.com/ie/ietemga2.htm
