Sediment and Battery light staying on- brightly ! HELP!!
Moondance_Scotland
Post by Moondance_Scotland » Mon Aug 18, 2008 4:46 pm
Both my charge light and sediment light are lit brightly on the dash, they have been like this for a few hours to- day. What does this mean? (Moonshine_Scotland) Very concerned, read the similar article in FAQ but not enough info there - mine has two batteries, no leisure set up as yet, not a conversion either.
Moonshine Scotland
p/s. any quick help would be appreciated please..
Re: Sediment and Battery light staying on- brightly ! HELP!!
Post by francophile1947 » Mon Aug 18, 2008 4:55 pm
It usually means that your alternator has packed up. If you've got a tester, check the battery voltage with and without the engine running - it should be a couple of volts higher with the engine running.
Post by missfixit70 » Mon Aug 18, 2008 5:15 pm
I'd agree with Franco, sounds like the alternator.
Magwa
Post by Magwa » Mon Aug 18, 2008 7:14 pm
Yeap your alternator has gone......
if the lights are still on when your ignition key is out you will have flat batteries in the morning.
sometimes the speed of discharge also kna***rs the batteries
disconnect the battery earth posts and source a new alternator
or be prepared for two new batteries and an alternator at worst!
Dooh :cry:
Live long die oblong
waycar8
Post by waycar8 » Mon Aug 18, 2008 7:19 pm
Just be carefull when purchasing another alternator as there was a batch of alternators that was for sale on ebay a couple of months back that were dodgy something to do with the bearing failing almost imidiatley, cant remember the sellers name but someone else may be able to confirm.
mister munkey
Post by mister munkey » Mon Aug 18, 2008 8:23 pm
T'was me that bought one, still got it if its any use to anyone who can source an 8mm shaft back bearing that will fit (needle roller bearing rather than the inadequate plain rollers it came with).
Apart from that its as good as new.
Can't remember the ebay name from where it came but was somewhere in Leicester I think.
:-k
Post by teenmal » Mon Aug 18, 2008 10:40 pm
Hi,Did you check the alternator drive belt.
Ps are you near Bellshill.
Regs Mal..
Magwa
Post by Magwa » Tue Aug 19, 2008 10:34 am
Ive PM'd you
DONT PANIC
just check the simple stuff first
Magwa :idea:
Post by haydn callow » Tue Aug 19, 2008 12:37 pm
a voltmeter across one of the battries.
Should read 12.5 volts +/- engine off.
Should read 14.5 volts +/- engine running.
12.5 engine running = duff alternator/broken wire/poor connection.
Double check by putting the red voltmeter probe on the BIG alternator terminal and black probe to earth again should read 14.5 +/- engine running.
zigzag
Post by zigzag » Tue Aug 19, 2008 8:40 pm
I had these two lights on last year - the problem was caused by water in the gutter below the windscreen, there is a drain hole there that gets blocked easily.
Post by Simon Jones » Tue Aug 19, 2008 9:38 pm
Zigzag - what was the rain water dripping on that caused the problem? Was it on the fuses?
ad_simmo
Post by ad_simmo » Tue Aug 19, 2008 10:23 pm
I bought a brand new Bongo alternator from http://myworld.ebay.co.uk/thestartermot ... torco.ltd/
£110 + £15 postage.
Much cheaper than the others I saw advertsied... and works a treat!
