Noise from front passenger wheel
oggy
Post by oggy » Sun Jul 20, 2008 3:12 pm
Hi all,
i am getting a funny noise coming from front passenger wheel when i am going around corners but only when on full lock can anybody help. [-o<
Oggy
dreamwarrioruk
Re: Noise from front passenger wheel
Post by dreamwarrioruk » Sun Jul 20, 2008 3:15 pm
cv joint
mike, jo and emma
oggy
Post by oggy » Sun Jul 20, 2008 3:18 pm
Hi mike is it an easy fix
Oggy
Post by missfixit70 » Sun Jul 20, 2008 3:34 pm
JUust check the flappy plastic bits aren't catching on the tyre - mine does occasionally :wink: Depends on the noise really :?
dp bradford
Post by dp bradford » Sun Jul 20, 2008 3:43 pm
Turn the front wheels to full lock and have a look at the rubber gaitor that's around the drive shaft on the inside of the centre of the wheel. If it's split or showing signs of leaking, then the CV Joint will be on it's way out.
Loud clicking noise???
Dave (just ordered a new pair myself!) 8)
dreamwarrioruk
Post by dreamwarrioruk » Sun Jul 20, 2008 4:13 pm
is it 4wd. the shafts can be a pain to separate, ie bashing it with a big hammer to take apart. i havnt done one myself but if you search on the forum. i think overall its easier to get a garage to do it.
a clicking noise on sharp corners indicates cv joint, does it do it when normal driving, sometimes ive seen a stone trapped which rubs on the brake parts which creates the same symptoms.
best guess would be cv but any decent garage would be able to determine if it is that.
mike, jo and emma
kawasaki kid
Post by kawasaki kid » Sun Jul 20, 2008 11:34 pm
Certainly sounds like a CV joint on the way out - can be a bugger of a job to do - took me over three hours just to get the driveshaft off the joint - been there , done it , don`t want to have to do it again. :roll:
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
zimmer
Post by zimmer » Tue Jul 22, 2008 8:13 pm
Hi, Before you change anything have a check round the wheel area. This is personal experience from 2 years ago. I found the plate at the rear of the brake assembly (thin metal plate) was slightly bent and rubbed on the wheel any time the wheels were put on full lock. The wheel bearing had been replaced 2 days earlier and the mechanic (?) hadn't fully tightened the wheel nuts. CV joints usually make a clicking type noise. Hope this may help.
Post by bigdaddycain » Wed Jul 23, 2008 12:58 am
I never had the typical clicking noise when my cv joint was goosed...just a distant graunching sound, only on right hand lock, it turned out to be the left hand side joint that was bust.
