just wondered if anyone had some instructions from another kit or some kinda plan so i can match up wires and get some idea
thanks!
chris
It was just a pointer to the circuit diagram timmyt asked for, the information is still correct. No one is insisting he fits that particular relay, he already has his relay. You just need to make sure that the other componet parts of the circuit are rated accordingly, that is also stated in the article.ps ive just seen the diagram and walkthrough, why do people insist on fitting such c**p relays. they are only rated at 30amp and last two minute, next thing you know the contacts have fused and you cant start the van due to a flat battery.
