coolant change
robdrinky
coolant change
Post by robdrinky » Wed Jul 16, 2008 5:37 pm
i changed the coolant and fitted a set of flippas hoses today(fitted a treat,thanks flippa).
flushed the rad and rest of system and pleased to see no sludge come out,condition of hoses was ok as well(still glad i changed them though)also fitted a new stat.
choose the mazda method to bleed the system and although i ran out of time to complete it(kids to collect etc).i noticed the temp went very high(almost to h on the dial) and the fans came on when reving to 2500rpm without the stat opening(bottom hose still cold) so i dropped the revs back.
my question is would it be normal whilst doing this for the temp to go up that much-i appreciate its got to get hot for the stat to open but that hot!
the voices made me do it!
P reg unconverted blue/grey 2.5td AFT
daveblueozzie
Re: coolant change
Post by daveblueozzie » Wed Jul 16, 2008 6:14 pm
have you checked your coolant tank to see if it has burped any air from the system, it does sound like youve an air lock.
you cannot rush the bleeding it has to be right.
Lost without my Bongo.
robdrinky
Re: coolant change
Post by robdrinky » Wed Jul 16, 2008 7:20 pm
wont be rushing it!
coolant level in tank dropped a bit but i kept it topped up also had coolant and air coming out of bleed pipe.
Re: coolant change
Post by haydn callow » Wed Jul 16, 2008 8:40 pm
Not normal for the guage to go HOT whilst bleeding. Be very careful.
robdrinky
Re: coolant change
Post by robdrinky » Wed Jul 16, 2008 9:09 pm
thanks for the info-umm hope i have not done any damage.
whats your opinion of the sort of temp should i expect to see on the gauge during bleeding.
Re: coolant change
Post by haydn callow » Wed Jul 16, 2008 9:28 pm
Normal...11 o'clock
Re: coolant change
Post by haydn callow » Wed Jul 16, 2008 9:29 pm
Just a thought...do you have a Mason alarm fitted?
robdrinky
Re: coolant change
Post by robdrinky » Wed Jul 16, 2008 9:51 pm
thanks.
yes i do have a mason alarm fitted-which did not go off,been wondering about that!
Re: coolant change
Post by haydn callow » Wed Jul 16, 2008 10:03 pm
Ah... nothing to worry about then...Mr Mason was just doing his job....
daveblueozzie
Re: coolant change
Post by daveblueozzie » Wed Jul 16, 2008 10:12 pm
i dunno 20 questions to get an answer, :lol: i had my mason alarm set at just under 5 but whilst towing a small caravan it did start to beep, so its now set at 5/6, and the temp guage did go to the red a couple of times.
robdrinky
Re: coolant change
Post by robdrinky » Wed Jul 16, 2008 10:13 pm
fitted it ages ago and i think i set it at 4 possibly 5.
Re: coolant change
Post by Bob » Thu Jul 17, 2008 12:34 am
robdrinky wrote:i changed the coolant and fitted a set of flippas hoses today(fitted a treat,thanks flippa).
I suspect your problem is here and you need to start from scratch. Good luck.
Re: coolant change
Post by bigdaddycain » Thu Jul 17, 2008 2:23 am
Was you getting good constant heat from the front and rear heaters rob? Unusual happenings with the heaters is indicative of an airlock, which i'm sure is what you may have.
Remember rob, you can't purge ALL the air from the sytem with the bleeding, the bongo needs to do this itself over the few following days after a coolant change.
That's why the level of coolant drops overnight after a bleed... There is the same amount of coolant in there, but naturally purged air in the system has caused the level to drop via displacement.
robdrinky
Re: coolant change
Post by robdrinky » Thu Jul 17, 2008 8:14 am
thanks for the constructive comments guys-all noted.
yes i will start from scratch when i get back to it,probably sat after work.
i did not have time to check the heaters bdc but will do.
Re: coolant change
Post by bigdaddycain » Thu Jul 17, 2008 10:33 am
The rear heater should be as hot as the front heater if the stat has opened, allowing the coolant to circulate around the system. :wink:
