Recommendation: Bongo friendly garage in Salisbury
Moderators: Bob, westonwarrior
Post by Simon Jones » Fri Jul 11, 2008 10:50 pm
Needed to get the air con serviced as it had not worked for a while, so was advised to go to New Garage in Salisbury. They didn't go 'Mazda wot?' when I told them what the problem was & have apparently dealt with them before. The air con chap is called John Curtis & did a great job getting it all going. He pressure tested the system, refilled using the correct type & qty of gas, added the PAG oil & also some UV dye & sealer as a precaution. He then left it running for 30 mins & checked all over for leaks with a UV light. He also cleaner out the evaporator bits too. No probs found & it's now icy cold.
That lot cost me £104 which is more than KwikFit would have charged, but it's worth paying the extra to get it done by a specialist who knows Bongos.
The contact details are:
New Garage
Unit 28, Harnham Trading Estate, Netherhampton Rd, Salisbury, Wiltshire SP2 8NW
Tel: 01722 321330
Re: Recommendation: Bongo friendly garage in Salisbury
Post by Bob » Thu Jul 24, 2008 11:42 pm
Thanks Simon.
Return to “Rest of the West”
