contacts for starter
Posted: Thu Jul 10, 2008 7:54 pm
by karen
i assume this is where to get them - there seems to be conflict info about the kits just have one. is this ok and you just clean othere or what's the script
ta
Starter solenoid plunger and contacts *230221/13256 . Auto electrical Supplies Southhampton. 023 80 211660.
Re: contacts for starter
Posted: Thu Jul 10, 2008 11:00 pm
by moonshine
Hi Karen.
I fitted just the one contact to my starter motor quite a while back, and cleaned the other one up ok. I have had no starting problems since.
Posted: Fri Jul 11, 2008 8:25 am
by nfn
The kits from Southampton come with both contacts now -- I bought from them in April. No starting problems since.
Posted: Sat Sep 06, 2008 3:43 pm
by 0x1de
Help. I bought the kit, but one of the contacts looks the wrong shape. Is it ok to use or should I wait until I can get a replacement?
Posted: Sat Sep 06, 2008 6:43 pm
by nfn
I would be inclined to try the new contacts anyway -- it's not too much time wasted if they don't work. At worst you can clean the old contacts up a bit and put them back in until Southampton Auto Electrics send the correct contacts. It's also possible that your bongo has a different starter to most others -- which could be the case if it was kitted out for extreme cold weather.
Posted: Sat Sep 06, 2008 7:58 pm
by waycar8
if you have the winter pack on your bongo then you have the uprated startermotor that no one has managed to get a replacement set of contacts for
Posted: Sat Sep 06, 2008 9:40 pm
by 0x1de
I don't think I have the winter pack. It's just that the contact is the wrong shape.
I've put some photos up here.
As you can see, the new contact (fitted) is symmetrical as opposed to the old one.
Posted: Sun Sep 07, 2008 8:25 am
by nfn
From the photos it doesn't look as if the incorrectly shaped contact will obstruct the plunger. You could phone Southampton Auto tomorrow and see if you can e-mail the pictures to them -- they will be able to tell you whether the differently shaped contact will work.
