Brake pads
Ame
Brake pads
Post by Ame » Mon Jun 30, 2008 2:53 pm
Ive just received my set of rear brake pads and notice that there is a small clip type attatchment that is rivetted onto the back of one of the pads but not any of the others.
I cant find it mentioned in the fact sheets or on other posts.
Can anyone give me advice as to whether this is normal? :?
Cheers Ames
cheffy34
Re: Brake pads
Post by cheffy34 » Mon Jun 30, 2008 6:01 pm
any chance of a piccie, i did my pads not long back :?:
Ame
Re: Brake pads
Post by Ame » Mon Jun 30, 2008 8:19 pm
Hopefully this is the link to a photo. The clip type attachment is on the second pad from the right.
Veg_Ian
Re: Brake pads
Post by Veg_Ian » Tue Jul 01, 2008 12:41 pm
That'll be the brake wear indicator. Did the ones you took off not have them? Should be one per pair.
Ame
Re: Brake pads
Post by Ame » Thu Jul 03, 2008 1:32 pm
AAhh. Thank you!
I havent replaced them yet as wanted to make sure this was the right set. There is only one clip on one pad. the other 3 dont have one.
scanner
Re: Brake pads
Post by scanner » Thu Jul 03, 2008 2:16 pm
Ame wrote:AAhh. Thank you!
In that case it probably fits on the inside of the near side front pair - check if there is a corresponding wire to connect to it.
Some cars only have one wear sensor and it's often on the N/S front for some reason.
Ame
Re: Brake pads
Post by Ame » Fri Jul 04, 2008 7:39 pm
That's great, will do.
Thanks for the advice. :)
