Temperature Gauge Voltage
Posted: Sun Jun 15, 2008 5:46 pm
Two quick questions:
Anyone measured the voltage at the rear of the gauge on the instrument panel, where the screw passes thru the T-U connection? I'm getting 8V on a fairly warm engine, but the needle has gone off the scale at the hot end. It was working fine until I did some work behind the instrument panel earlier.
Is there a 12V regulator built in to the instrument panel (as is the case in other vehicles)? With the engine running, I'm getting 13.8V at the IG screw on the rear.
Many thanks.
Many thanks.
