Removing side windows for tinting.
Hi everyone, I've just become the proud owner of 4WD Bongo, camping for the first time this weekend and can't wait.
I want to tint the windows but haven't got a clue how to remove them. Can anyone out there give me instructions on how to take each of the side windows out please? Have just been quoted 100 quid plus vat to have the side windows tinted, is this good value? Thanks.
- You've Been Bongod
Re: Removing side windows for tinting.
Hi Miles
welcome to the nut house yes £100+ vat is good value for window tinting don't forget to put in your profile which area you are from
NeilT put a post about window tinting on pimp my bongo section as he has done his own hope this helps
you've been bongod
you've been bongod
Yeah, I've tried to get into that post before, but whatever I do, i can't access the link from this site to his post on the bongoforum. I've even set up a login but still can't seem to access the link he put in. Not sure what I'm doing wrong?
Here is fact sheet
http://www.igmaynard.co.uk/bongo/forum/ ... nt#p120433
However it doesn't say how to take the windows out](./images/smilies/eusa_wall.gif)
Get 2 of these big sucker things for holding/carrying glass - also sold as dent pullers in your local pound shop, get someone to stand outside holding the window with those while you clip off the the 3 plastic covers on each window on the hinges & catch, undo the screws, you'll have to force back the plastic trim slighty on the catches to get the screwdriver in, but it can be done
That's it. if the rubber bits on the window are fubar I think bongobits sell them, good luck.
Mind you that's not a bad price you were quoted either as long as they do a decent job, I've seen some sketchy "professional" tints
Any tips on how to put the hinge covers backon?
I took my trim off to get the windows out, but forgot to fit the covers back on
Just put them in place then with a blunt but thin thing (say about 4mmx20mm) give them a good thump and they will click into place. You can just use the philips screw driver that you use to undo the windows, but this can just aas easily split the plastic cover as I have found out.jarog wrote:Any tips on how to put the hinge covers backon?
I took my trim off to get the windows out, but forgot to fit the covers back on.
Personally I leave the hinges in place and unscrew the 2 fittings that are in the window (best taken off to tint anyway). The lock side I just push the pin out and remove the other bit on the window once on the ground.
Its not difficult to tint, but there is a knack, and I havent quite got it yet
For a good job, £100 is definitely a reasonable price though.
Shouldn't be difficult to get the hinge covers back on, I didn't have to remove the trim to tint the windows, just pull it back gently & there's enough room to get in there
All of my windows were done in situ by cutting the film around the obstructions for £150 - perfect job.
Hi everyone, decided to save myself the hassle and get the windows tinted professionally. £141 after the dreaded VAT. Really pleased with the result. The vehicle looks so much better
. Away for the weekend in it now, off to a new camp site near Asbourne in Derbyshire. Thanks for your help.
post piccy's please when you get back
you've been bongod
you've been bongod
