Turbo Working?
Turbo Working?
Hi all,
First post for a relatively new Bongo owner.
We've just had our Bongo serviced for the first time and my mechanic is convinced the turbo isn't working. I must admit when I bought it back in Nov 07 I thought it was a bit slow but having nothing to compare it with I assumed that this was the norm.
We get no turbo noises, no kick when (if) the turbo starts spinning and most worryingly it won't go over 60mph up any sort of hill. When I dab the accelerator there is a noticeable delay before the engine revs to say 4000rpm.
Is this normal?
Cheers,
Kev
Is this normal?
Cheers,
Kev
Re: Turbo Working?
Blimey that was quick.
Thanks for the advice. I'll check the filters when I've sussed where they are.
It's the inclines where I notice the lack of speed most. Having said that its not particularly quick at getting up to speed on the flat either although i've had it up to 85mph. Generally I just cruise at 70.
All the other turbo vehicles I've had produce the usual whizzing sound and give you a push in the back when the turbo kicks in.
Re: Turbo Working?
On ours there was no noticeable kick or noise as the turbo
came in but it definitely worked plenty of power, look on the
injection pump you should have a small bore rubber pipe
that runs round to the turbo, these are often off, don't
know if they blow off or are taken off for some reason but
if it is put it back and you will feel the difference.
- brorabongo
Re: Turbo Working?
Sounds about right to me. Check this thread about the same symptoms...........Ralph wrote:On ours there was no noticeable kick or noise as the turbo
http://www.igmaynard.co.uk/bongo/forum/ ... e&start=30
Re: Turbo Working?
It should up hills at over 60 mph but it will depend on the hill
It does sound like yours is a bit flat but Bongo's aren't exactly sporty. Have a look at that little pipe .
Re: Turbo Working?
Without the little pipe the injector pump doesn't know the turbo is blowing and so doesn't pump in the extra fuel needed to make best use of all the extra air.last_tuesday wrote:It should up hills at over 60 mph but it will depend on the hill
If that is off you will find it goes much better with it re-fitted but your MPG will probably drop as a result.
Re: Turbo Working?
I couldnt wait to get back from work to check this injector pipe thing out. Surely it couldn't be that easy and surely I wouldn't be that lucky. I whipped the drivers seat up and lo and behold no vaccume pipe! I found it laying on the engine and shoved it back onto the injector pump and took Billy for a test drive.
Blumin nora the difference is unbelievable. Our once docile bongo now goes like the clappers! Straight up to 70+ uphill on the local bypass.
Cant thank you Bongoliers enough. I owe you all a drink. We're driving out to Klagenfurt in Austria in four weeks time and this will make the journey so much easier.
Cheers,
Kev
Cheers,
Kev
Re: Turbo Working?
Brilliant news perkster24 and just in time for your hols. You will now discover just what a great cruiser the Bongo really is. I tell ya, the guys and gals on here know their stuff.
If you are going long distance, have you taken precautions. I'm thinking of the low coolant alarm. Get one fitted a priori if you haven't got one already. The next pipe that comes off could be a coolant one, and you don't want a cracked head in Klagechexkenffffurrrr....wherever
- brorabongo
Re: Turbo Working?
Great news.perkster24 wrote: Cant thank you Bongoliers enough. I owe you all a drink. We're driving out to Klagenfurt in Austria in four weeks time and this will make the journey so much easier.
but, I for one will not be going over to Austria, just to collect my drink!!!
All the best.
Re: Turbo Working?
Well done guys that's the value of this place. Plus the friendship and p**** taking.
Re: Turbo Working?
Always good to find a cheap & easy fix
Have a good holiday guys.
Re: Turbo Working?
Swaat I look for on my hols, mostly cider.missfixit70 wrote:Always good to find a cheap & easy fixHave a good holiday guys.
Re: Turbo Working?
When we bought our Bongo we spent hous surfing the Fury site and concluded that the engine alarms were well worth havng. Ive fitted a Mason alarm and have purchased the water level one but havent fitted yet. Suffice to say it will be going on before our hols.mikeonb4c wrote:Brilliant news perkster24 and just in time for your hols. You will now discover just what a great cruiser the Bongo really is. I tell ya, the guys and gals on here know their stuff.
If you are going long distance, have you taken precautions. I'm thinking of the low coolant alarm. Get one fitted a priori if you haven't got one already. The next pipe that comes off could be a coolant one, and you don't want a cracked head in Klagechexkenffffurrrr....wherever![]()
Re: Turbo Working?
And he didn't check the hose was connected?perkster24 wrote:Hi all,
I think you need to show him what was wrong............................he might learn something.
Re: Turbo Working?
Great news and well doneperkster24 wrote:When we bought our Bongo we spent hous surfing the Fury site and concluded that the engine alarms were well worth havng. Ive fitted a Mason alarm and have purchased the water level one but havent fitted yet. Suffice to say it will be going on before our hols.mikeonb4c wrote:Brilliant news perkster24 and just in time for your hols. You will now discover just what a great cruiser the Bongo really is. I tell ya, the guys and gals on here know their stuff.
