Having trouble finding that very small leak ???
Google......tracerline.......good stuff.....there may be somthing available locally which does the same job.
Coolant leak detector
- haydn callow
Re: Coolant leak detector
Useful tip, expensive kit so v interested if anyone finds a good alternative (u/v dye and cheap u/v lamp)
- haydn callow
You can buy just a bottle of fluid and get a bulb that will go in a small torch.
Yea but, where from. I tried searching but no luck so far.haydn callow wrote:You can buy just a bottle of fluid and get a bulb that will go in a small torch.
