Changing bulbs in rear lights of new style Bongo
Hi - I have seen the guidance sheet on replacing light bulbs on a Bongo (and particularly replacing bulbs on the rear side of the vehicle) but with the new style Bongo there are also bulbs in the rear door - how do you change them? I want access to them as there's condensation built up.
Re: Changing bulbs in rear lights of new style Bongo
I have some condensation in mine but in the other ones on teh bodywork.
I suspect you have to remove the inner door panel to get access but I'll take a look tomorrow. I can't recall seeing any obvious way of getting into the lights on the door itself from the outside.
Andy
Andy
Thanks to both of you for your advice - would be interested if you have any luck, Andy
Julian
Julian
