Hissing sound
Peg leg Pete
Hissing sound
Post by Peg leg Pete » Sun Jun 01, 2008 8:03 pm
Driving home today noticed a hissing sound coming from passenger side rear, Not sure just where it is coming from :?: as only hear it when vehicle is moving :roll: sound is not constant, more intermittent :roll: Any ideas please.
Image Pete
Re: Hissing sound
Post by francophile1947 » Sun Jun 01, 2008 8:05 pm
No idea - unless you've lost your pet snake :lol: :lol: :lol:
trevd01
Re: Hissing sound
Post by trevd01 » Sun Jun 01, 2008 8:07 pm
waycar8
Re: Hissing sound
Post by waycar8 » Sun Jun 01, 2008 8:08 pm
Manifold stud broken?
Peg leg Pete
Re: Hissing sound
Post by Peg leg Pete » Sun Jun 01, 2008 8:28 pm
It is not a screeching sound Wayne, more like a leaky airline :roll:
Image Pete
Jolly Rogers
Re: Hissing sound
Post by Jolly Rogers » Sun Jun 01, 2008 8:42 pm
I would check your hoses.
I had the exact noise in my Bongo. Turned out to be a small hole in one of the hoses.
Best to check it out.
Peg leg Pete
Re: Hissing sound
Post by Peg leg Pete » Sun Jun 01, 2008 8:44 pm
I will do, was raining hard when we came home, so will check level of coolant now all has cooled down :wink:
Image Pete
Peg leg Pete
Re: Hissing sound
Post by Peg leg Pete » Sun Jun 01, 2008 8:56 pm
Coolant level fine :wink:
Image Pete
waycar8
Re: Hissing sound
Post by waycar8 » Sun Jun 01, 2008 8:59 pm
do you check the pipes conected to the turbo Pete?, can you here it on idle or just when you put your foot down?
Peg leg Pete
Re: Hissing sound
Post by Peg leg Pete » Sun Jun 01, 2008 9:03 pm
Have not checked turbo yet Wayne, will do it in daylight Did not hear sound when stationary and revved engine, just when running low revs when moving, :roll:
Image Pete
You've Been Bongod
Re: Hissing sound
Post by You've Been Bongod » Sun Jun 01, 2008 9:04 pm
leaky valve in a tyre?
or stone in tyre as that can sound the same ?
you've been bongod
Peg leg Pete
Re: Hissing sound
Post by Peg leg Pete » Sun Jun 01, 2008 9:07 pm
Cheers Carl have been parked on gravelly carpark, tyre pressures are fine, so will check trye treads in the morning, thanks for the prompt helpful responses(and the funny ones too :wink: )
Image Pete
Jolly Rogers
Re: Hissing sound
Post by Jolly Rogers » Sun Jun 01, 2008 9:17 pm
Is it a wooshing sound just before it changes up gear?
Really advise you to check your hoses when the engine is running.
I ignored the sound for a while, then i noticed it was loosing coolant and that turned out to be quite costly.
Dolly1
Re: Hissing sound
Post by Dolly1 » Sun Jun 01, 2008 9:25 pm
Maybe window not closed fully,or,door rubber not sealing properly.Just a thought !!
SARAH & LIONEL - I Used to be Citroen 2CV "DOLLY" mad but BONGO-MAD lady with not so mad husband now!
Peg leg Pete
Re: Hissing sound
Post by Peg leg Pete » Sun Jun 01, 2008 9:30 pm
It is an external sound, will check hoses :wink: been there with the costly leaking hose before :roll:
Image Pete
