HELPPPPPPPPP Water from behind pully wheels
D n D & K
Post by D n D & K » Thu May 22, 2008 7:50 pm
can anyone help just notice we have water coming from somewhere it looks like its behind the pully wheels so i am guess a seal must have gone some where . is this a job i could o myself or is it a specail tool garage job ,
any help greatly received
Damian Donna & Kayleigh
Re: HELPPPPPPPPP Water from behind pully wheels
Post by missfixit70 » Thu May 22, 2008 7:53 pm
Sounds like the water pump gone, try a search, or wait for a fellow sufferer to happen along :(
brorabongo
Post by brorabongo » Thu May 22, 2008 7:58 pm
Beat me to it Missfixit!!
The water pump pulley is the top one along from the alternator, Seems easy enough to replace, no specialist tools required AFAIK. As Missfixit says try searching using...... water AND pump
best of luck
ボンゴの激怒 pictures
D n D & K
Post by D n D & K » Thu May 22, 2008 8:01 pm
thanks better go back out side and see if the water is that high up did not check that high earlier but now you have said that i will check again
brorabongo
Post by brorabongo » Thu May 22, 2008 8:09 pm
Are you paid-up members? if so there is a good wee fact sheet in the members area, on how to replace pump etc.
ボンゴの激怒 pictures
Post by bigdaddycain » Thu May 22, 2008 8:10 pm
If you have to use the bongo in the mean time, it may be an idea to carry a few litre bottles of water/coolant with you just in case D D & K.... :wink:
D n D & K
Post by D n D & K » Thu May 22, 2008 9:51 pm
thanks all . yes we are members . have looked at fact sheet thanks .
maybe see you at the bash
erifis
Post by erifis » Mon May 26, 2008 9:45 pm
Its your water pump, replace it as soon as you can.
If you are having to top up the header tank and you can see water coming from behind the top pulley wheel at the front of the engine block, its definitely a new water pump job.
cheers, hope that helps, same happend to me, new rad & head before I worked out it was the water pump.
Think a new one was around 50 pounds, same as the mazda b series, haven't lost a drop of water since I changed it.
