Heater motor bushings
veefour
Post by veefour » Tue May 20, 2008 10:50 am
Anyone know what is the part no. or comparable part for the heater motor bottom bush is.Mine is badly sized and need's replacment. I have checked through the fact sheets and cant find any info on part no.s or replacment bushes.
Re: Heater motor bushings
Post by Doone » Tue May 20, 2008 11:25 am
I haven't looked, is it listed here? http://www.lushprojects.com/bongopartsmk2/
veefour
Post by veefour » Tue May 20, 2008 1:06 pm
Thanks but it looks like it's just the motor complete. I need the bearing. Must be able to get a bearing separate from the motor?
Post by Ian » Tue May 20, 2008 1:08 pm
veefour wrote:Thanks but it looks like it's just the motor complete. I need the bearing. Must be able to get a bearing separate from the motor?
Not through Mazda I'm afraid. They only sell the whole motor.
Ralph
Post by Ralph » Tue May 20, 2008 2:36 pm
If it's made of bronze and you can get it out without destroying
it you could try dropping it in some hot oil then leaving it for a
day or two clean up the shaft and it should run OK.
