parawaiting
Post
by parawaiting » Wed May 14, 2008 12:35 pm
i successfully changed my fuel filter last night and when i started again which took a lot of turning over which i assume was due to the fuel having to flow through the filter, anyway i was a bit shocked when i saw a steady drip of fuel coming from around the fuel pump area- it was getting too dark last night so will have another look today to see exactly. i am a bit confused as to why this has suddenly happened, i returned from a long drive on monday night so i would have definitely noticed if i had been loosing fuel before.
does anyone have any ideas why this might have happened or has it happpend to them? i am not too keen on taking the fuel pump apart but loooks like i'll have to
i think i have loooked at most of the threads about leaks but if anyone has any ideas i would be very grateful
cheers
paul
Veg_Ian
Post
by Veg_Ian » Wed May 14, 2008 1:33 pm
It appears to be a common fault for the O ring to fail. If you find Dandywarhol's thread it shows how to fix it with a series of photos. Just a coincidence that it should fail after changing the filter - unlucky!
parawaiting
Post
by parawaiting » Mon Jun 09, 2008 6:32 pm
Coolhand
Post
by Coolhand » Mon Jun 09, 2008 11:23 pm
where abouts from the pump is it leaking? I've just changed the same seals as you but found I also have a leak coming from the 3 side bolt plug on the rear of the fuel pump. This one drips at start up but then stops as everthing warms up.
I've got the replacement seal from Lawson Diesels and am now waiting fo delivery of the 3 sided bolt socket which I have ordered from Merlin Diesels.
oglivy0
Post
by oglivy0 » Tue Jun 10, 2008 12:27 am
The leak could be coming from the plug at the rear of the pump.The seal is easily replaced.Remove the injection pipes and the connectors these are screwed to,be careful not to lose the springs etc.which come out with the connectors.Unscrew the plug using a pipe wrench or similar tool and replace the seal.
Coolhand
Post
by Coolhand » Tue Jun 10, 2008 7:25 am
[quote="oglivy0"]The leak could be coming from the plug at the rear of the pump.The seal is easily replaced.Remove the injection pipes and the connectors these are screwed to,be careful not to lose the springs etc.which come out with the connectors.Unscrew the plug using a pipe wrench or similar tool and replace the seal.
Has anyone done this, I am after advice on what parts I will need to remove to gain access to undo the pipes from the fuel pump. Will I get a lot of fuel spillage when I undo the pipes?
parawaiting
Post
by parawaiting » Tue Jun 10, 2008 9:22 am
Post
by mikeonb4c » Tue Jun 10, 2008 1:54 pm
Good luck and keep us posted Parawaiting. Lessons learned could be usefully added to any factsheet on fixing leaking injectors. Matters little to me unfortunately I tried to do my O rings and did my back in, resulting in a week off work. Can't do jobs like that nay more it seems
oglivy0
Post
by oglivy0 » Wed Jun 11, 2008 9:44 pm
Coolhand wrote:oglivy0 wrote:The leak could be coming from the plug at the rear of the pump.The seal is easily replaced.Remove the injection pipes and the connectors these are screwed to,be careful not to lose the springs etc.which come out with the connectors.Unscrew the plug using a pipe wrench or similar tool and replace the seal.
You don't need any special tools just some spanners and not a lot of leakage either just what's in the pipes.The pipes are easy to remove.
parawaiting
Post
by parawaiting » Thu Jun 12, 2008 3:22 pm
update is im waiting for the 3 sided socket tool and full seal kit from merlin diesels, gasket and seal kit was a fiver dont ask how much the 3 sided tool was! didnt fany it with molgrips as there is not much room to manouver.will udate with progress
The Great Pretender
Post
by The Great Pretender » Thu Jun 12, 2008 10:18 pm
The o ring is easy to repace once you have a tool to undo the stupid triangular nut. I made a socket for it.
Repacing it took all of 15 minutes then.
This is it removed.
To infinity and beyond
Coolhand
Post
by Coolhand » Sun Jun 15, 2008 1:48 am
Did mine today with the socket from Merlin Diesels. Had to remove injection pipes 1 to 3 (to gain access), but did not need to remove the unions in the back of the fuel pump. The socket comes with a 14mm square spigot which fitted into my torque wrench once I had removed the square driver from it (the torque wrench).
Post
by mikeonb4c » Sun Jun 15, 2008 10:15 am
Coolhand wrote:Did mine today with the socket from Merlin Diesels. Had to remove injection pipes 1 to 3 (to gain access), but did not need to remove the unions in the back of the fuel pump. The socket comes with a 14mm square spigot which fitted into my torque wrench once I had removed the square driver from it (the torque wrench).
Thats good news. Was there any problem getting the pump to prime and engine to fire afterwards? And can you tell yet if its fixed the leak?
I've got a slightly leaky injector and I'm thinking that as well as the O rings it might be good to get this done at the same time if it is straightforward.
Coolhand
Post
by Coolhand » Sun Jun 15, 2008 8:50 pm
mikeonb4c wrote:Coolhand wrote:Did mine today with the socket from Merlin Diesels. Had to remove injection pipes 1 to 3 (to gain access), but did not need to remove the unions in the back of the fuel pump. The socket comes with a 14mm square spigot which fitted into my torque wrench once I had removed the square driver from it (the torque wrench).
Didn't have to do anything special to prime just turned her over for about 10 to 15 seconds (didn't tough the accelerater) as each cylinder started to catch.
Fixed the leak from the three side bolt however I still have a very slight weep coming from the screw located in the lower righthand corner (looking from the rear forward) of the distribution block (same block that the 3 side bolt is screwed into).
Anyone know what this bolt does?
The Great Pretender
Post
by The Great Pretender » Sun Jun 15, 2008 10:13 pm
If you mean the bolt in the middle of the 3 sided nut it is for bleeding the pump. It seals with a copper washer.
